Thermostat housing
Old Nov 1, 2024 | 11:02 AM
Rishi's Avatar
Default Thermostat housing
Is there any good reason why my 1965 3.8L would have a later type (or XJ6) thermostat housing? Maybe simply a replacement inlet manifold?
Old Nov 1, 2024 | 11:14 AM
Rishi's Avatar
I think I have managed to answer my own question. Just took a good look at the cylinder head and it looks like a straight port head to me. There is no blank plug in front of the spark plug at the front of the engine.
Old Nov 1, 2024 | 11:23 AM
Peter3442's Avatar
To use an XJ or 420 manifold requires a straight port cylinder head as the inlet ports are positioned differently from the Mk2's usual B type head. If you have a SP head, the spark plugs on the outermost cylinders (1 and 6) will be towards the ends of the engine sides of the cylinders (rather than towards the middle of the engine as on the B type). Also, I think most SP heads don't have an engine number stamped on them (on the valley side of the timing chain box).
Old Nov 1, 2024 | 11:30 AM
Rishi's Avatar
I searched for the engine serial number on the head and there is none.
The first photo is the plug at the front of the engine and the second one is the plug at the back.
I feel a bit like an archaeologist.
Old Nov 1, 2024 | 12:20 PM
Peter3442's Avatar
Yes, that looks like a straight port, generally considered a useful upgrade.
Old Nov 1, 2024 | 12:34 PM
Peter3442's Avatar
Does your car have its original engine?
Old Nov 1, 2024 | 12:55 PM
Rishi's Avatar
That's a question I have been trying to ascertain for a while. I have looked for the serial number by the oil filter but it is so faint it is really difficult to see. The original engine was LE2200-9 which is on the plate and confirmed by Jaguar heritage. The engine has 3.8 Litre stamped on it. This is the best picture I have of the serial number and I am pretty sure I can see LE 220.... and on another picture I can pretty clearly see -9 so I think it is the original.
Old Nov 1, 2024 | 01:07 PM
Peter3442's Avatar
https://www.jag-lovers.org/xk-lovers...20spark%20plug.
LE.... is correct for a 3.8 Mk2. The -9 would indicate a 9:1 compression ratio. In your photo of the rear end of the head, it's just possible to see a number stamped on a raised area at the end of the casting. It's a sequence number from the Jaguar machine shop. From what I understand, they reached GC... and GX... about late 1969 to early 1970.
Old Nov 2, 2024 | 08:57 AM
Rishi's Avatar
The stamp on the back of the head looks like DN331
Old Nov 2, 2024 | 11:02 AM
Peter3442's Avatar
My best guess would be that the cylinder head and manifold came from a 420. I don't know how to prove it or take the archaeology any further. Hopefully, someone else will have a few ideas?
Old Nov 2, 2024 | 12:00 PM
Rishi's Avatar
At least I know what I have under the bonnet now and I won’t be buying the wrong thermostat gasket again! Thanks for thinking along with me.
bladerunner919
Sep 9, 2024 07:27 AM
Psycom
Aug 24, 2024 12:18 AM
Todd Wiens
Apr 5, 2023 01:58 AM
Stamford
Aug 23, 2020 01:40 PM
ez64
Jul 25, 2011 10:38 AM
