tricky tricity
Old Apr 10, 2014 | 06:00 PM
billj's Avatar
Default tricky tricity
Hi,
I am in the process of attaching an alternator /ps pump assembly to a 3.4S.The alternator is rated at 80 amps,which may be too much for the wiring.I propose to use a 30-40 amp auto reset circuit breaker to prevent power surge to wiring.If the battery is fully charged at all times the circuit breaker should not trip.
Any suggestions ,anyone?
Old Apr 11, 2014 | 04:48 AM
Jose's Avatar
I would consult with Retro Air / Mr. Jaguar who sells the alternator you are considering.
Jaguar Mark II, IX, 3.4, 3.8 S, Power Steering Alternator for OE Pump
Old Apr 11, 2014 | 10:17 PM
billj's Avatar
Thanks Jose,The alternator assy is o.k.,I have made one.I am interested in hooking up the alternator with 80 amps to the existing wiring without smoking it.I realise the alt will only put out what's required,but I want to limit the output to 30-40 amps.
Old Sep 18, 2014 | 12:31 PM
blurooster's Avatar
the 80 amp rate is for charging and use. I have used 130 amp alternators on wiring not as robust as Jaguar without problems.
Old Sep 18, 2014 | 05:10 PM
primaz's Avatar
I am using a battery isolator system due to the three battery system but I am using a 100 amp alternator on my 3.8s
RaceDiagnostics
Jul 7, 2022 06:41 AM
stevis05
Dec 2, 2020 10:26 PM
rvdz
Dec 7, 2019 06:42 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
yeldogt
Sep 27, 2015 01:57 PM
