windshield seal big probleme
Old Jul 6, 2018 | 05:37 PM
dan025's Avatar
Default windshield seal big probleme
Hello everyone
I am restoring my Jaguar Mk2 in France.
I am mounting the windshield joitn and chrome chopsticks. I bought totu new at SNG BARRAT FRANCE.
Look at the windshield seal in photo.
The seal cut when I try to put the chopsticks chrome.
You have a solution ?
Thanks for help me
Sorry for my English, I use Google Translate
Bonjour ŕ toutes et ŕ tous
Je suis en train de restaurer ma Jaguar Mk2 en France.
Je suis en train de monter le joitn de pare brise et les baguettes chromé. J'ai acheté totu neuf chez SNG BARRAT FRANCE.
Regardez le joint de pare-brise en photo.
Le joint s'est coupé quand j'essaye de mettre les baguettes chromé.
Si vous avez une solution,
Merci pour votre aide
Désolé pour mon Anglais, j'utilise Google Translate
Old Jul 7, 2018 | 05:30 AM
dan025's Avatar
New seal received this morning from SNG BARRAT.
Same reference but two different joints there is not a hitch there?
Look closely at the shape of the two joints laid flat.
Nouveau joint reçut ce matin de chez SNG BARRAT.
Męme référence mais deux joints différents il n'y a pas comme un hic lŕ ?!
Regardez bien la position des deux joint posés ŕ plat.
Old Jul 8, 2018 | 09:41 AM
Jose's Avatar
French man, I wish I could help you but I think you have to fit the glass and seal first, then the chromed moldings.
In the picture it looks like there is no glass?
Old Jul 9, 2018 | 12:38 AM
TilleyJon's Avatar
I am not sure what you mean, are you saying they have the same part numbers ?
One is the rear window and the other is the front, what problems are you having ?
Je ne suis pas sűr de ce que vous voulez dire, dites-vous qu'ils ont les męmes numéros de pičce?
L'un est la fenętre arričre et l'autre est l'avant, quels problčmes avez-vous ?
Old Jul 9, 2018 | 06:16 AM
dan025's Avatar
Hi
We received a new seal and it is posed, the other model was not the correct one, there was an error on the part of the supplier
Nous avons reçut un nouveau joint et il est posé, l'autre modčle n'était pas le bon, il y a eu une erreur de la part du fournisseur
Old Jul 9, 2018 | 04:01 PM
Fraser Mitchell's Avatar
Did you take the windscreen out yourself ? If you did, you will know there are two parts that make up the seal - (1) the seal itself, and (2) a filler strip that expands the seal once the windscreen and seal is fitted to the car. Normally a special tool is needed to fit the filler into its slot in the seal. It is a long time since I fitted the windscreen to my Mark 2, (around 1987), so my memory may have faded so apologies. However as I recall, the seal is fitted to the windscreen first, then a long piece of string is wound twice round the outer slot in the seal leaving the two ends next to each other. The windscreen and seal combination is then offered up to the car by two people, then one of those persons keeps the windscreen pressed against the aperture whilst the other person pulls gently but firmly on the two string ends thus pulling the seal over the steel lip of the screen aperture until it is all nicely installed. The filler strip is then inserted using the special tool so that the ends meet at the bottom of the screen. Finally a sealing mastic is applied to the glass-seal lip, and the seal-body lip, and the surplus cleaned up.
Old Jul 9, 2018 | 04:08 PM
dan025's Avatar
The windshield is installed.
the filling strip is a chrome partier?
if so we'll put it soon.
Le pare brise est installé.
la bande de remplissage est une partier chromé ?
si oui nous allns la mettre bientôt.
Old Jul 10, 2018 | 05:00 PM
Sorry, I forgot about the chrome trims, (chromed brass, by the way).
The chrome trims fit over the top of the filler strip to hide it and make the car look good. The seal has two lips that the trim fits under each side. Again, there used to be special tools that made fitting easier, but you should be able to improvise, but take care not to scratch the trims !
Old Jul 11, 2018 | 04:44 PM
dan025's Avatar
thank you very much, everything is in place.
But look at the chopsticks sold by SNG BARRAT, it is impossible to mount them, so we restored the old ones and we mounted them:
merci beaucoup, tout est en place.
Mais regardez les baguettes vendues par SNG BARRAT, il est impossible de les monter, alors nous avons restauré les anciennes et nous les avons monté:
dan025
39
Jul 8, 2018 09:47 AM
primaz
16
Feb 18, 2016 09:22 PM
NTL1991
XJ40 ( XJ81 )
Nov 15, 2013 06:00 PM
Big Cat !
Nov 10, 2013 07:17 PM
Bruce in North Dakota
Jan 2, 2011 06:57 AM
