probleme motor chauffage MK2
Old Sep 26, 2017 | 04:30 AM
dan025's Avatar
Default probleme motor chauffage MK2
Hy sorry me not speak french, traducte to google translate
impossible to find the heating linkage that goes from the tap to the flap
Old Sep 26, 2017 | 04:33 AM
dan025's Avatar
Default cherche pieces original
Old Sep 26, 2017 | 04:38 AM
dan025's Avatar
Hello from France.
Sorry but not speak English.
My search the piece for my Jaguar Mk2 2.4L
search the cable control flap original and cable from hot water tap
thans for the response
best regards Daniel
Old Sep 26, 2017 | 05:40 AM
Jose's Avatar
cherche = Search
chauffage = heater / heating
He is searching for the rod or cable to the heater air flap or heater valve.
Old Sep 26, 2017 | 02:56 PM
TilleyJon's Avatar
Dan,
take a look at this post, Mk2 gave me a drawing and I made one from some 3mm stainless steel rod.
https://www.jaguarforums.com/forum/m...9/#post1688109
Jon
Old Sep 26, 2017 | 05:27 PM
dan025's Avatar
Hi John
My hot water is double connection, one for the cable, one for the tap.
Old Sep 27, 2017 | 12:29 AM
TilleyJon's Avatar
The other parts should be on this page, the rod is not available.
SNG Barratt - The Ultimate Jaguar Parts Specialist
does this help ?
Old Sep 27, 2017 | 01:42 AM
dan025's Avatar
Hi,
SNG Barrat it's not the room for that I'm here
Old Sep 27, 2017 | 11:09 AM
TilleyJon's Avatar
Not sure what you mean, translation didn't work.
SNG do have an outlet in france, so you should have no problem.
Old Sep 27, 2017 | 12:06 PM
dan025's Avatar
My called at SNG barrat the piece for flap is not disponible
Old Sep 27, 2017 | 12:26 PM
Mikey's Avatar
disponible= available
Old Sep 27, 2017 | 12:45 PM
TilleyJon's Avatar
What part number are you after ?
Google translate-
Quel numéro de pièce voulez-vous? C16614 ?
If it is this part you can make one from 3mm stainless rod, see the picture from the post I put a link to for the dimensions.
Google translate-
Si c'est cette partie, vous pouvez en faire une à partir de la tige en acier inoxydable de 3 mm, voir la photo à partir du message sur lequel j'ai mis un lien pour les dimensions.
Old Sep 27, 2017 | 03:39 PM
SNG Barratt USA's Avatar
Former Sponsor
We do have a branch in France, they can be reached via the below and speak English & French fluently, maybe they can help.
SNG BARRATT FR
62 CHEMIN DU BOIS D'ALIER
ZONE DES BERTHILLIERS
CHARNAY LÈS MÂCON
71850
FRANCE
T: +33 385 201420
E: france@sngbarratt.com
Old Sep 27, 2017 | 05:22 PM
dan025's Avatar
Hi SNG Barrat USA.
I am a client at Barrat France, me call to home, the pieces is not disponible in France...
Old Sep 27, 2017 | 05:23 PM
dan025's Avatar
Hi TilleyJon
or have you found this reference c166614?
ou avez vous trouverez cette référence c16614?
Old Sep 27, 2017 | 05:50 PM
Mikey's Avatar
Hi TilleyJon
Where have you found this reference c166614?
He meant where, not or.
Old Sep 28, 2017 | 12:54 AM
TilleyJon's Avatar
Hi TilleyJon
In the parts catalog also on SNG, but not available. You will have to make it as I said before.
Google translate
Dans le catalogue des pièces également sur SNG,
mais pas disponible. Vous devrez le faire comme
je l'ai déjà dit.
Old Sep 28, 2017 | 02:51 AM
dan025's Avatar
Ok thanks Tilley John
Old Sep 30, 2017 | 04:42 PM
a1lry's Avatar
JAGUAR MK2 /V8/E-TYPE S3 HEATER / CHOKE CABLE C21373* | eBay
Old Oct 1, 2017 | 10:39 AM
dan025's Avatar
Hi guys
Question:
For open the flap is okey in the pictures?
But my flap is not ok!
Me push A in right, the flap is bloqued!
