Wiring the Wiper Motor on a 3,8 S Type
Old May 3, 2018 | 06:25 AM
re-hiker's Avatar
Default Wiring the Wiper Motor on a 3,8 S Type
How ist Wiper motor connected 1. Speed, 2. Speed Stop
Thanks for your help re-hiker
Old May 3, 2018 | 01:04 PM
Homersimpson's Avatar
The motor has around 5-6 wires, its operation is quite complicated.
In simple terms it has power to the armature winding's and also the field coil that runs the motor at half speed.
Around the field coil is wrapped a resistance wire, when this is brought into circuit the field coil output is reduced and the motor spins faster to operate at normal speed.
When turned off the motor actually turns backwards before stopping which is why the motor is called a reverse park unit.
I found the diagram in the link below helped me understand how it works and then you need the vehicle wiring diagram to see how its all connected.
http://coachedby.me/lucas-dr3-wiper-...tfathers-me-in
If all the wires are in place and the colours are still visible its probably better to connect it up as per the car wiring diagram and not look too closely into how it works, it just does!
Old Jun 20, 2024 | 11:00 AM
Felixbobcat's Avatar
Do not click on the above link by Homer SImpson.
It is Malware and will lock up your computer.
I found out the hard way.
Old Jun 20, 2024 | 11:01 AM
Old Jun 20, 2024 | 11:12 AM
Glyn M Ruck's Avatar
Here is Hi Res Diagram in colour. Blow up as big as you want. I have a large laminated copy on my garage wall. This is safe.
Marley
Apr 26, 2023 09:27 PM
Wilfred88
Apr 14, 2016 02:10 PM
GuBe
Apr 6, 2016 01:30 PM
Dleit53
Nov 8, 2014 04:31 PM
ohkyguy
Oct 17, 2012 02:11 PM
