XJ6 centre gearbox lever on MK2
Old Sep 16, 2013 | 04:37 PM
raym's Avatar
Default XJ6 centre gearbox lever on MK2
Hi decided to start a new post on this subject to see if anyone has advice and/or pictures of how this is accomplished. I understand that the Borg Warner 35 gearbox was also fitted to the XJs so hopefully it is quite a simple change
Basically I have an automatic 340 with column shift and I have purchased an XJ6 gearbox centre selector and am wondering how this is installed. I have seen MK2's with this mod but would like any advise possible.
I had thought about using the old centre console but I figure it would be best to put an XJ version as well to include arm rest.
Attached Thumbnails XJ6 centre gearbox lever on MK2-dscf0023.jpg   XJ6 centre gearbox lever on MK2-dscf0038.jpg
Old Sep 17, 2013 | 03:12 AM
barrymk2's Avatar
Hi ray, I have fitted a bw65 from an xj6 to my mk2. Using the xjchange mechanism as you. I mounted the lever to the tunnel, then took the ski slope ( cover) from the cosole then cut a hole in the cover to suit. The console will fit over the lever, the front of the lever is level with the front of the round hole for a manual shift, then cut to the rear to suit.
You then need to alter the slope on the console to accomadate the cable etc.
I welded a peice of metal along each side and finished with body filler.
I have not trimmed it but it is basicaly the same just reprofiled
barry
Old Sep 17, 2013 | 03:16 AM
barrymk2's Avatar
Default Pictures
Ray, I would send you some pics but dont know how!!!!!!!!!!
barry
aholbro1
Dec 29, 2024 06:46 PM
Ozzy_UK
Sep 24, 2015 08:44 PM
BSM
Mark V - X 420G
Sep 14, 2015 08:35 AM
1964Daimler
Sep 9, 2015 11:28 AM
pnwrs2000
Sep 3, 2015 11:55 AM
