1985 Jaguar xjs V12 need help with injectors not firing
Old Mar 31, 2023 | 02:10 AM
Justin 1985 Jaguar XJS V12's Avatar
Exclamation 1985 Jaguar xjs V12 need help with injectors not firing
Purchased a 1985 Jaguar V12 no start for 350 dollars with wires unplug as well as things missing ( see attatched photos ) been reading alot of post from all of you on here thanks to all the post
I reconnected what i learned so far and replaced spark plugs gapped at 0.025 as well as the wires, fuel pump fuel filter and some fuel lines
wasnt able to get power to the pump at key position 2 or 3 but was able to get power to the pump by running a wire from the ignition amplifier to pin #18 of the ecu ( 6cu) will be upgrading that to a 16cu as some research says they are better,
so here is where im at and need help
-now i have spark and it fires up for about 5 seconds or so injectors are not firing and i also want to know if anyone could help me figure out the vaccum advance hoses and where they go and also how to get the injectors to fire up, oh yeah i had to delete the cats because no airflow was able to get through thats when it fired up
would greatly appreciate it.
File Type: mov
Old Mar 31, 2023 | 03:52 AM
Welcome to the Forums.
STRONG suggestion, get on bended knee and ask GGG (Graham) AKA "The Boss", to move this to the XJS Tech Section.
I have "stickies" at the top for just this.
I can and will work with you on this, as will others, BUT, not in this section.
These are SIMPLE cars, so dont over think it.
Old Mar 31, 2023 | 04:13 AM
Daf11e's Avatar
Welcome aboard Justin….listen to the Guru above, Grant Francis.
Old Mar 31, 2023 | 06:08 AM
Welcome to the forums Justin,
With Grant's hint, I've copied your question to XJS forum for advice from members with the same model. Here's the link to it:
https://www.jaguarforums.com/forum/x...firing-268580/
Follow this link https://www.jaguarforums.com/forum/xjs-x27-32/ to the main XJS forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Southwest Region forum by following this link https://www.jaguarforums.com/forum/us-southwest-37/ to find other members in your region.
Enjoy the forums.
Old Mar 31, 2023 | 07:40 AM
appreciate it thank will do.
Old Mar 31, 2023 | 07:50 AM
welcome to the forum - enjoy!!!!
Old Mar 31, 2023 | 10:15 AM
Hello, Justin,
What a Steal you have there!
I say that because, even though right now you have a $350 piece of Junque, Grant Francis above is one of our Gurus who knows V-12s inside and out. You could not do better than to learn at his knee.
Old Mar 31, 2023 | 10:29 AM
Welcome to Jaguar Forums Justn,
Old Mar 31, 2023 | 10:31 AM
Got lucky with the car and the Wisdom of Grant Francis.
thank you Elinorb.
Justin
Old Mar 31, 2023 | 10:35 AM
greatly appreciate that i will try to do that and write to get this thread moved by GGG and also not to over think this restoration and repair of the XJS V12.
thank you Grant Francis
Justin
Old Apr 1, 2023 | 03:34 AM
Justin
Justin,
I COPIED your thread to XJS forum rather than MOVE it. This gives the opportunity for all members who follow Intro's to see yours here and for the XJS experts to follow the troubleshooting in XJS forum.
DeepJag
Aug 11, 2016 01:51 PM
Mlb
Mar 24, 2013 08:32 PM
alicat
Jul 6, 2010 09:20 AM
beeturbo
Jun 16, 2008 02:03 AM
Brake buster
Mar 9, 2008 11:07 AM
