1990 jaguar xj6 starter will not disengage
Old Nov 27, 2011 | 11:23 AM
bootman's Avatar
Default 1990 jaguar xj6 starter will not disengage
Hi ,i am working on a 1990 xj6, when you turn the key to start , the starter stays engaged when and if it starts. I replaced the ignition switch assembly, tumbler, key and switch with a used one, same problem , tryed swapping out relays, same problem. I guess i will try removing starter and checking it out, any sugestions would be appreciated.
Old Nov 28, 2011 | 04:01 AM
Welcome to the forum.
Sounds like your starter, unfortunately.
Have fun.
Old Nov 28, 2011 | 07:14 AM
bootman's Avatar
Thanks, have you had the same problem. i am still wondering if the used switch i got is bad
Old Nov 28, 2011 | 07:27 AM
Welcome to the forum,
You should ask in the XJ6 section for the best technical advice.
Old Nov 28, 2011 | 07:47 AM
bootman's Avatar
how do i post to xj6 section
GuernseyJag
Nov 8, 2017 10:40 AM
adenshillito
Feb 17, 2016 07:05 AM
Doug S
Sep 10, 2015 01:53 PM
david5201u
Australia - Western
Aug 29, 2015 12:50 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
