1998 XJS Driver seat does not return to position when key is put in ignition
Old Mar 20, 2012 | 12:56 PM
gsinoc3's Avatar
Default 1998 XJS Driver seat does not return to position when key is put in ignition
1998 XJS. Everyting about the power seats, mirrors, stearing wheel etc works perfectly. Even the instructions for programming the key fob work as described. The only thing that does not work is when I turn off the car the seat goes all the way back (good thing) but when I enter the car and put the key in the ignition the seat does not return to the original set position. As I said earlier when following the user manual to set the memory buttons and the key fob buttons it all seems to program correctly. Everything else adjust properly- the mirrors, the stearing wheel but not the drivers seat. Any suggestions? Thanks in advance for your help
Old Mar 20, 2012 | 03:22 PM
Fraser Mitchell's Avatar
You are likely to get an answer on the XJS forum, as this is the New Members forum, and not all XJS experts look in here all that often
Old Mar 20, 2012 | 03:25 PM
gsinoc3's Avatar
Thanks, Still learning how this site works
Old Mar 21, 2012 | 07:59 AM
welcome to Jaguarforums, good to have you here with us
If you add your car details to your signature it will help others to help you much more quickly.
+1 on Frasers comments...........get there and I'm sure th guys will be happy to help if they can
I've manually upgraded you to full forum access so you can better view the site and all its features so jump on in and enjoy
Old Mar 23, 2012 | 01:01 PM
Welcome to the forum,
The XJS experts will help.
kurtomatic
Feb 12, 2024 06:58 AM
hafren
Aug 30, 2023 03:42 PM
Jandreu
Aug 29, 2015 07:31 PM
aquifer
Aug 29, 2015 04:54 PM
