2003 XJR Engine light and restricted performance
Old Dec 16, 2012 | 09:10 PM
bigevent's Avatar
Exclamation 2003 XJR Engine light and restricted performance
Hey guys, I have a 2003 XJR Supercharged with 67000 miles on it. two weeks ago the Engine light and restricted performance popped on. It went into limp home mode. After restarting it did fine but the light and restricted performance stays on now. My mechanic said it shows the electronic throttle may have been damaged by a detailer. I've driven around and sometimes the Light comes on sometimes it doesn't. Sometimes the restricted performance comes on. I drove awhile today and neither came on. The next time I started they were both on. My other mechanic says the throttle may not be the only problem. Any ideas?
Old Dec 16, 2012 | 11:58 PM
Welcome to the forum bigevent,
You will need to post up the details of your problem in the tech section which will be either XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum or XJ ( X350 & X358 ) XJ6 / XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum you should get the codes read to help with the diagnosis.
When you get the chance take a look in your regional section Southern MidWest - AR LA MS KY TN AL - Jaguar Forums - Jaguar Enthusiasts Forum
Old Dec 17, 2012 | 02:09 AM
Follow Norri's link to the X308 section for help, advice and information. You should post the actual DTC error codes and not just the descriptions whoever reads them may give you.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
I hope it's an easy fix.
Old Dec 17, 2012 | 03:47 AM
steveinfrance's Avatar
Welcome to this friendly Forum. Definitely follow Norri + Graham's advice to get your problem sorted.
Old Dec 17, 2012 | 11:31 AM
Hey welcome aboard....... good to have you here with us here at Jaguarforums
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
Terrance Williams
Aug 26, 2015 11:50 AM
NinoGrimace
Aug 26, 2015 05:15 AM
