2005 XJ8 rad flush problems
Old Oct 26, 2014 | 08:17 AM
Jaguar brg's Avatar
Default 2005 XJ8 rad flush problems
Hi Everyone,
I have a 2005 Xj8 4.2 that i had a lube shop do a rad flush on. The car had no coolant problems prior to the flush, and maintained the temp gauge always steady in the middle. I only did the flush as routine maintenance.
Since the flush, which has been burped tirelessly, buy undoing the small bleed cap to the left of the main rad cap (with the main rad cap refilled, and closed)
I have had problems...The car takes a long time to move the needle up and rarely hits the middle mark anymore. also after 20 -30 mines driving. The temp gauge shoots to hot, and the car warning lights come on. All i do everyday is pull over, shut the engine off. restart and everything returns to where it was. The Heater does work fine, i have heat OK, and when it has been burped it is with the heater on full. What can the fast lube shop have done wrong when they changed the coolant.
Old Oct 26, 2014 | 09:13 AM
Hello,
Members over in the Xj8 section will doubtless be able to help you with your cooling issue.
Old Oct 26, 2014 | 09:59 AM
Welcome to Jaguar Forums Jaguar brg,
I've copied your post into the tech section for a better response, you can find it here https://www.jaguarforums.com/forum/x...oblems-129714/ and you will find your regional section here USA Western - AK CA NV OR UT HI WA ID - Jaguar Forums - Jaguar Enthusiasts Forum
Old Oct 26, 2014 | 11:19 AM
Welcome to the forum Jaguar brg,
Follow Norri's link in post #3 to the X308 forum for help, advice and information.
Enjoy the forums.
Old Oct 26, 2014 | 06:48 PM
Helpful_information
Old Oct 27, 2014 | 06:50 AM
o1xjr's Avatar
Old Oct 27, 2014 | 07:28 PM
ZJag
26
Sep 5, 2016 03:33 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
KarimPA
Sep 3, 2015 07:32 PM
laserguy
Sep 3, 2015 02:02 PM
rachelstr
Sep 3, 2015 12:59 PM
