99xjr goes into limp mode when put into reverse.
Old Jun 23, 2024 | 03:36 PM
Leighdone's Avatar
Default 99xjr goes into limp mode when put into reverse.
The car will seem to engage reverse hard and if it does then transmission fault will display and the vehicle will only drive in limp mode ( no power and acceleration)
it does not always do this, there can be a couple of days at a time when everything is fine, and then the problem resurfaces.
it only happens when selecting reverse.
When the problem has not occurred the car shifts perfectly and sport mode works fine.
this has been going on for about a year now with no change. There is no deterioration in the way the car shifts ( unless the fault light shows up in reverse as described) so it’s
hard for me to see this as a transmission problem
All fluids are new and full and the car just turned over 100k
Old Jun 23, 2024 | 05:02 PM
Daf11e's Avatar
Welcome aboard.
Old Jun 23, 2024 | 08:54 PM
Welcome to the Forums.
Since this is NOT the Tech Section, I suggest a re-ask in the XJ8/R (X308) Tech Section, down the home page a tad.
Good luck.
Old Jun 24, 2024 | 07:54 AM
Welcome to Jaguar Forums Leighdone;
I've copied your post to the tech section, follow this link to find it https://www.jaguarforums.com/forum/x...everse-281446/
Old Jun 24, 2024 | 08:24 AM
Hello, Leighdone,
As Grant above suggests, members of our XJR section will certainly be able to help you out with this transmission fault.
But it IS annoying to have an Intermittent fault like that!
Old Jun 25, 2024 | 11:29 AM
welcome to the forum
Rebbecca
Mar 19, 2026 07:54 AM
garyfdl
Sep 5, 2022 06:39 PM
William Wells
Jul 7, 2017 07:25 PM
Roxanne
Apr 26, 2017 05:18 AM
bigted
Mar 20, 2013 08:15 AM
