AC only cold when I drive fast
Old Apr 10, 2015 | 11:07 AM
reachchristine's Avatar
Question AC only cold when I drive fast
I have a 2003 Jaguar S-Type...suddenly the AC stopped cooling when driving under 60 MPH. stopped and had the Freon changed they said it was half as full as it should be, but after they filled it, nothing has changed, still only cools when I am driving on the freeway...they did say they found a small leak in the compressor but that it should still last me a while, but as soon as I left the shop it was back to doing the same thing?
Old Apr 10, 2015 | 05:14 PM
Welcome to the forum reachchristine,
Follow this link S-Type / S type R Supercharged V8 - Jaguar Forums - Jaguar Enthusiasts Forum to the S-Type forum for help, advice and information.
You can also visit the USA Southwest Region forum by following this link https://www.jaguarforums.com/forum/usa-southwest-az-tx-nm-ok-37/
Enjoy the forums.
Old Apr 10, 2015 | 06:15 PM
Old Apr 10, 2015 | 07:42 PM
Welcome to Jaguar Forums reachchristine,
There is a tsb that may help. Head to the tech section for all the info.
Old Apr 11, 2015 | 07:12 AM
o1xjr's Avatar
Old Apr 11, 2015 | 10:03 AM
Using JF "How To"
Old Apr 11, 2015 | 11:40 AM
Muddydog's Avatar
AC only works when you drive fast? Is no one else going to point out the obvious solution here?!?!
Old Apr 12, 2015 | 08:50 PM
cergun's Avatar
Hi reachchristine, welcome to the forum. I am also very new but have been stalking for a while.
I am not sure if this is the correct place to answer the question but I had the same problem with another make and it appeared to be a fan problem. mine had 2 fans and one of them was blowing to the wrong direction "after a repair".
You may have some kind of a fan problem.
Old Apr 15, 2015 | 04:00 PM
European_Auto11558's Avatar
Sounds to me like the freon level is either too low/high, condenser fan not operating or operating under speed, back drier/accumulator. I would begin to check these in that order. If all is well then there there is a little more in depth issue.
JarodL
Mar 7, 2024 01:39 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
Corycarlo
Sep 5, 2015 11:41 AM
dcvickers
Sep 2, 2015 06:14 PM
