Buying first Jag on Saturday
Old Nov 7, 2021 | 11:39 AM
ajwickham's Avatar
Default Buying first Jag on Saturday
Just had an offer accepted on a 2002 XK8 in Antigua Blue. Picking it up on Saturday, and then the adventure begins.
Old Nov 7, 2021 | 12:27 PM
Welcome to the forums Alan,
Follow this link https://www.jaguarforums.com/forum/xk8-xkr-x100-17/ to the XK8/XKR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
I can see you've already viewed the guidance for new members so no need for a prompt from me.
Enjoy the XK8 and the forums.
Old Nov 7, 2021 | 01:33 PM
szhilian39's Avatar
Wow, congrats. I'm looking to buy an xk-8 myself.
Plz, upload some pics. cheers.
JW
Old Nov 7, 2021 | 03:46 PM
Daf11e's Avatar
Welcome aboard Alan.
Old Nov 7, 2021 | 06:46 PM
Hello, Alan,
Congratulations on your new Jaguar Xk8!
I decided some time ago that an Xk8 will be my Next Jaguar. All I need to do is add another stall to the garage...........
Old Nov 8, 2021 | 01:52 AM
o1xjr's Avatar
Welcome to the forums.
Old Nov 8, 2021 | 02:49 AM
Welcome to the Forums.
Old Nov 8, 2021 | 04:35 AM
Welcome to the forum Alan,
Old Nov 8, 2021 | 05:19 PM
Old Nov 16, 2021 | 11:26 AM
ajwickham's Avatar
So the adventure begins with a battery almost completely drained the day after I drove it home. Not a huge surprise as the seller did say it was draining in a couple of days. Once my battery charger arrives I'll try the graphite in the ignition trick, and if that doesn't work I'll start looking for the fuse box.
Old Nov 16, 2021 | 01:06 PM
Make room for a CTEK on your Christmas list.
Old Jan 2, 2022 | 10:07 AM
ajwickham's Avatar
Thanks Graham 😊 I did indeed buy a trickle charger and the car started up. With my new meter I discovered that it was pulling 1A with nothing on. Putting graphite in the ignition reduced that down to 200mA, the first of many times to thank this forum. 200 mA shows there is still a problem, but that's lower down the list.
I have an alternating 'Electrical fault' 'Suspension Error' showing on the dash but my new code reader shows only P1000. Everyone says start with a new battery, I put a brand new Yuasa YBX5019 in, but no joy.
This thread Electrical fault / suspension fault has been fixed by replacing a diode behind the drivers side (UK) fuse box. I'll check the appropriate fuse first (gotta buy some fuses first!), and then the diode, and then I'll be pulling out the seat I guess.
Old Jan 2, 2022 | 05:24 PM
P1000 is OnBoard Monitoring tests NOT completed. Someone has cleared the codes recently or your would have P1111 (OnBoard Monitoring tests complete). One of these two status codes is always present.
Sportsmed
Sep 18, 2016 10:30 AM
Poppyboy
Oct 18, 2014 07:14 AM
bkrdoug
Oct 16, 2011 11:11 AM
spector
Sep 1, 2009 06:10 PM
