Coolant leaks
Old Oct 1, 2017 | 04:36 AM
Neil1983's Avatar
Default Coolant leaks
Hello. Does anybody have a diagram of the coolant system. I have a leak in a hose just below the starter motor. The hose finishes just above the oil filter. Can't find the name of the part to order. Thank you.
________________
2006 X-Type Estate 2.0 ltr diesel (added by GGG)
Old Oct 1, 2017 | 04:49 AM
Robman25's Avatar
Hi Neil, it rather helps to know what car you are asking the question about, also if you can post a picture even better.
Old Oct 1, 2017 | 05:40 AM
Welcome to the forum Neil1983,
Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information.
The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/
Enjoy the forums.
Old Oct 1, 2017 | 06:15 AM
Welcome to Jaguar Forums Neil1983,
Old Oct 1, 2017 | 07:08 AM
Welcome to the Forums.
Old Oct 1, 2017 | 09:09 AM
Hello, Neil,
Old Oct 1, 2017 | 09:19 AM
Old Oct 1, 2017 | 11:13 AM
Neil1983's Avatar
hello. Sorry about the lack of info. It's a 2006 jaguar x type estate. 2lt diesel
I do not have any pictures as it's still on the car. Thought I had repaired it properly the first time
thanks
Neil
Old Oct 1, 2017 | 01:14 PM
Neil,
Here's the relevant extract from JEPC (Jaguar Electronic parts catalogue) for the X-Type (diesel) cooling system hoses:
If you can identify the hose, I can lookup the part number.
Old Oct 1, 2017 | 06:13 PM
Daf11e's Avatar
Welcome aboard Neil.
Old Oct 2, 2017 | 12:32 AM
o1xjr's Avatar
Welcome to the forum.
Old Oct 3, 2017 | 04:08 AM
Busa's Avatar
Hi Neil, welcome to the forum !
Plenty of excellent help and advice on here.
Old Oct 3, 2017 | 04:40 AM
Neil1983's Avatar
Smile Coolant leak
Thank you for sending the diagrams. I have taken the pipe off again. Can anybody identify it from the pictures?. It is only about a foot long with a twist in it. It comes starts just above the starter motor and finishes below. As you can tell I am a novice repair man
Neil
Attached Thumbnails Coolant leaks-img_2042.jpg   Coolant leaks-img_2043.jpg   Coolant leaks-img_2044.jpg   Coolant leaks-img_2045.jpg
Old Oct 3, 2017 | 04:41 AM
Neil1983's Avatar
P.s. The third image...It connects to the small pipe almost in the middle of the image. Not the larger one in the bottom right section
Old Oct 3, 2017 | 05:02 AM
Neil,
I've copied your question to X-Type forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/x...-leaks-190115/
Old Oct 3, 2017 | 05:05 AM
Neil1983's Avatar
Thanks Graham.
