fuel sending unit xk-140
Old Jul 13, 2021 | 09:02 AM
jag smith's Avatar
Default fuel sending unit xk-140
How do i keep the sending unit from leaking?
Old Jul 13, 2021 | 09:43 AM
Welcome to the forums jag smith,
As I recall the XK150 sender unit was secured to the tank with a number of setscrews and sealed with a circular rubber gasket. Presumably the XK140 is a similar arrangment?
Follow this link https://www.jaguarforums.com/forum/x...k140-xk150-60/ to the XK120 XK140 XK150 forum for help, advice and information. You can also use the US Midwest Region forum by following this link https://www.jaguarforums.com/forum/us-midwest-39/ to find other members in your region.
Enjoy the forums.
Old Jul 13, 2021 | 05:50 PM
Daf11e's Avatar
Welcome aboard.
Old Jul 13, 2021 | 07:22 PM
Welcome to the Forums.
Old Jul 13, 2021 | 07:50 PM
Hello,
All sending units I've ever seen have some sort of gasket or O-ring to seal the unit against the tank.
This would be the first place I would look if this was my car.
Old Jul 14, 2021 | 03:35 AM
o1xjr's Avatar
Welcome to the forums.
Old Jul 14, 2021 | 04:33 AM
Welcome to Jaguar Forums jag smith,
Old Jul 14, 2021 | 05:10 AM
Old Jul 14, 2021 | 08:22 AM
Coventry Foundation's Avatar
As important as the gasket is the copper washers need to be fresh and the mounting surface as well as the sender itself need to be flat and true. Often folks tighten down the screws hoping to stop a drip and distort the sending unit face. As the sender is under the fuel level at anything over half tank if all is not correct it will leak. Suggest you obtain new copper washers--a new gasket--drain your fuel to less than half a tank--remove the sender and inspect. Best of luck.
Jagfixer
Jan 16, 2016 10:53 AM
sneal46
Feb 20, 2011 12:06 PM
