Gearbox, Delay in engaging drive
Old May 4, 2013 | 11:36 AM
bluexpeter's Avatar
Smile Gearbox, Delay in engaging drive
My 4.0L S type 2002 with 5R55N auto box experiences a delay when selecting Drive from the Park position. My instinct is to replace the Forward engagement spring, although other sources suggest I should re-program the PCM to the latest calibration level, others suggest a cable problem. Any advice most welcome as to do this by trial and error looks costly and time consuming.
Old May 4, 2013 | 12:01 PM
Welcome to the forum bluexpeter,
You should head on over and post up the details in the tech section S-Type / S type R Supercharged V8 - Jaguar Forums - Jaguar Enthusiasts Forum most important is which box you have in 2002 there are two possibilites 5 or 6 speed, don't forget to look in the regional area also UK - Jaguar Forums - Jaguar Enthusiasts Forum
Old May 4, 2013 | 12:10 PM
Follow Norri's link to the S-Type section for help, advice and information before reaching for your wallet! The 'HOW TO' thread at the top there is a good place to start for info on regular issues.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
Old May 5, 2013 | 05:57 AM
bluexpeter's Avatar
Smile Thanks
Thanks Guys, I have to admit I was unsure where to post this issue. I have re-posted it in the Tech issue section, sorry if that's against the rules i.e. posting the same issue twice! As far as I know it's a 5 speed box. Again any help most appreciated
Old May 5, 2013 | 07:07 AM
Although we usually 'have a word' about post whoring as it's known, in this instance I'd have copied it to S-Type tech section for you anyway as that's where the experts are to be found on this transmission issue.
Good luck.
Old May 5, 2013 | 07:50 PM
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
Any useful site information you may need such as how to post pictures, edit signatures, add videos,
use the search facility etc, can be found here within the following link Helpful_information
Old May 6, 2013 | 10:37 AM
bluexpeter's Avatar
Smile Delay in engaing Drive from Park
Thanks Jim. I have just ordered a book from USA: Ford 5R55N Automatic Transmission ATSG Rebuild Manual
Hopefully will give me some more insight into the issue.
cissdm
May 3, 2016 06:02 AM
afterburner1
Dec 16, 2015 12:12 AM
Xkr x100
Sep 6, 2015 08:50 AM
pnwrs2000
Sep 3, 2015 11:55 AM
XJsc-guy
Sep 2, 2015 11:43 AM
