Gearbox fault warning
Old May 18, 2013 | 02:31 PM
Rick Douglas's Avatar
Exclamation Gearbox fault warning
I have a 1998 XK8 4 litre. It starts up ok, but dashlights flickering and engine running a bit rough. The messages are: Traction Control fail, stability control fail and gearbox fault. Help wanted please!!
Old May 18, 2013 | 03:13 PM
Welcome to the forum Rick,
You will get good advice if you post all the details in the tech section XK8 / XKR - Jaguar Forums - Jaguar Enthusiasts Forum
Don't forget to check the regional section also UK - Jaguar Forums - Jaguar Enthusiasts Forum
Old May 18, 2013 | 06:21 PM
Welcome to the forum Rick,,
Follow Norri's link to the XK8/XKR tech section for help, advice and information. The 'HOW TO' thread at the top there is a good place to start for info on regular issues.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
Old May 19, 2013 | 02:17 AM
steveinfrance's Avatar
Welcome to this friendly Forum,
Follow Norri and Graham's advice and enjoy your membership here.
Old May 26, 2013 | 09:09 PM
Welcome aboard....... good to have you here with us here at Jaguarforums
Any useful site information you may need such as how to post pictures, edit signatures, add videos,
use the search facility etc, can be found here within the following link Helpful_information
Old May 26, 2013 | 09:55 PM
avt007's Avatar
Rick, it sounds like you have voltage issues. Do a bit of searching here, and check out your false bulkhead connector, the engine ground strap, and the battery itself.
scooternva
29
Mar 25, 2025 12:45 PM
cissdm
May 3, 2016 06:02 AM
scooternva
19
Oct 27, 2015 02:14 PM
Ozzy_UK
Sep 24, 2015 08:44 PM
BSM
Mark V - X 420G
Sep 14, 2015 08:35 AM
