Grinding sound from left rear
Old Feb 19, 2012 | 08:51 PM
Jet jockey's Avatar
Default Grinding sound from left rear
97XK8, 130k, I am the new owner of this car, previous owner gave up on fuel tank repair (pump, rust). He had removed entire rear end. I have the car together and running, car is in beautiful shape, but it emits a grinding sound from the left rear. Does not make it with moderate or hard acceleration or foot off the gas. I can hold slight accelerate force and cause the noise ( slight load or no load on bearings. Break pads are nearly new, park brake shoes properly adjusted, cable adjusted per forum recommendations. Shake test - slight play (normal) u - joints , everything's tight. It's not a bearing rumble, more like a grinding, worn out, mis aligned break pad. I can feel it when it grinds it creates a sensation ( shudder) in the drive train. Hope I've been descriptive enough as this doesnt seem to exactly match other forum noise in - the - rear problems. Planning to pull the hub and remove bearings just so I'll know.
Old Feb 19, 2012 | 09:05 PM
plums's Avatar
Have a look at the post from Beav at the bottom of:
https://www.jaguarforums.com/forum/x...driving-68451/
Old Feb 20, 2012 | 05:43 AM
Welcome to the forum,
Have a read of the post Plums linked to then see what the guys think.
Old Feb 20, 2012 | 06:31 PM
welcome to JF good to have you here with us ....
I've manually upgraded you to full forum access so you can better view the site and all its features so jump on in and enjoy
Old Feb 27, 2012 | 11:36 AM
Jet jockey's Avatar
Thanks for the suggestions. Have had several friends listen to this sound. They tell me it is a noise from the exhaust vibrating against something. Makes since because I had the entire rear end out of the car. I just have to find it now.
mbergen
Oct 23, 2019 10:26 PM
JagBrian
Aug 18, 2019 05:07 PM
PMKimpton
Aug 3, 2019 08:22 PM
Tar
Sep 6, 2015 11:24 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
