Jaguar x308 faults
Old May 7, 2012 | 07:35 AM
tjcd.davis's Avatar
Red face Jaguar x308 faults
Hi
New member but not to jags, Never had so many niggling problems with a jag before.
Finding info on the x308 impossible,but hopefully I may hav more success here.
Parked the car last week and it hasnt moved since,its only done 50,000 miles.
Thought it was electrics but have now proved it is fuel problem
what do you suggest New filter or pumps. I assume the pumps can not be cleaned/serviced.
Any suggestions appreciated
Jensens dont have these problems
TD
Old May 7, 2012 | 10:30 AM
bryce804's Avatar
Welcome to the site! Head over to the tech section for the x308. Im sure they would be able to give you some suggestions and help.
Old May 7, 2012 | 11:23 AM
Welcome to the forum,
That's good advice, post in the tech section and someone will have an idea, but do include allthe symptoms, codes, what you have done etc.
You're just having a laugh about the Jensen, aren't you?
Old May 7, 2012 | 12:47 PM
Welcome to the forum.
Good to see you.
Yes we have quite a few FP threads in the X308 section. IIRC there is a method of hot wiring the secondary pump when the primary packs in.
(Oh, check your inertia switch, you never know).
Old May 7, 2012 | 05:29 PM
Welcome TD,
Good advice to check the XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum section. Plenty of info and advice there.
Old May 7, 2012 | 07:32 PM
Hi TD, welcome to Jaguarforums, good to have you here with us
If you add your car details to your signature it will help others to help you much more quickly.
In the meantime I've manually upgraded you to full forum access so you can better view the whole site and all its features
so jump on in and enjoy
Old May 12, 2012 | 11:55 AM
tjcd.davis's Avatar
No the Jensen starts every time - had it 25 years
Mind you this is the first Jag Ive starting problems with - bring back the XJ6/4.2
Thanks for the contact
TD
Old May 12, 2012 | 11:59 AM
tjcd.davis's Avatar
Good to see you.
It would be usefull if I could find the secondary pump
Sent for manual from emanuals - hope this has more info
philwarner
Dec 6, 2021 07:13 AM
Robert1968
Jun 24, 2017 11:16 AM
rudelover2
Sep 11, 2015 08:53 PM
bjelliott
Sep 1, 2015 10:30 AM
plums
General Tech Help
Sep 1, 2015 06:34 AM
