Jaguar xjs steering /driving issue
Old Nov 12, 2021 | 02:01 PM
Kallum irwin's Avatar
Default Jaguar xjs steering /driving issue
Hi all I have not long purchased a 1989 xjs v12 85000 on the clock when I brought the car a few weeks ago on the drive back I could feel that the car was dangerously pulling to the left when I was on the motorway passing lorries and when there was cross wind the car was all over the road ! It was a very scary 200mile drive I also took it out the other night (after doing a repair job to the power steering pipe that also went pop on that same journey 😅 ) I noticed the steering wheel was very wavey when driving at 30 and didn't feel likeninhad properly controle of the car what do you all think the issue could be i am thinking warn steering rack bushes am I correct ?
Old Nov 12, 2021 | 03:33 PM
o1xjr's Avatar
Welcome to the forums.
Old Nov 12, 2021 | 05:27 PM
Welcome to the forums Kallum,
I also think the bushes are a likely culprit. Members with the same model will be better informed than me.
Follow this link https://www.jaguarforums.com/forum/xjs-x27-32/ to the XJS forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Old Nov 12, 2021 | 05:36 PM
Daf11e's Avatar
Welcome aboard Kallum.
Old Nov 12, 2021 | 05:37 PM
Doug's Avatar
Correct. Common failure.
There might be other causes such as tires separating, wear elsewhere in the suspension, or the wheels badly out of alignment. But, yes, the rack bushings are the first thing to look at.
Old Nov 12, 2021 | 06:19 PM
Old Nov 12, 2021 | 07:57 PM
Hello, Kallum,
I can tell you from personal experience that in fact steering rack bushings can make a car behave just as you describe.
While you're checking those out, it would also be a good idea to take a Very close inspection of lower wishbone bushings.
Old Nov 13, 2021 | 01:47 AM
Welcome to the Forums.
As mentioned, and also, ALL the rubber components are now past their intended use by date.
The stickies at the top of teh XJS section Graham has directed you to will give you a heads up.
Good luck.
Old Nov 13, 2021 | 07:14 AM
Welcome to the forum Kallum,
TheOrganLoft
Aug 5, 2013 09:11 PM
