left front window
Old Nov 3, 2013 | 06:03 PM
jagzee's Avatar
Default left front window
2003 XJ has a intermittent drivers (only) window which wont work unless a hard reset is completed with the battery.
The battery checks good, a good used door module has been replaced,with the same result.
No wiring issues found in the door. The other 3 windows work fine.
If the driver's door module is disconnected and reconnected the window will work fine for days.
Car is kept indoors and temperature doesn't seem to be a factor.
Old Nov 3, 2013 | 06:41 PM
Welcome again jagzee,
As A Jag Tech, you'll know 2003 was a model change year.
Follow this link XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 forum or this one XJ ( X350 & X358 ) XJ6 / XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X350 forum for help, advice and information.
Old Nov 3, 2013 | 07:49 PM
Hey there and welcome aboard ....... good to have you here with us here at Jaguarforums
If you need any further help with the site, please just ask any moderator, veteran member and we'll be glad to assist.
search facility etc, can be found here within the following link Helpful_information
Need a Manual, a TSB, or looking for General info about your Jag? Check out our >> DOWNLOAD AREA <<
See you in the forums....
Old Nov 3, 2013 | 10:54 PM
Welcome to Jaguar Forums jagzee,
Old Nov 4, 2013 | 06:18 AM
welcome to the forum and the Jag family - definitely plenty of info and support here to keep the cat running properly. You will find this to be the best tool in the owner's tool box.
Old Nov 4, 2013 | 06:31 AM
runnerpaul's Avatar
Default Welcome!
Hi Jagzee,
Thank you for joining this forum, and welcome from the Midwest Region.
You will find a wealth of information here.
You are in the right forum to get help fixing your window issue.
Please check out the link in my signature, this will help you link up with the Midwest members that are local to you.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Tar
Sep 6, 2015 11:24 AM
