Long time owner..First time forum
Old Apr 26, 2020 | 05:16 PM
Boudxk8's Avatar
Default Long time owner..First time forum
Hello All! My hope is this introduction finds you safe and secure.
I have been a proud owner of my Sapphire Blue 2000 XK8 since 2005. With family and a hectic career, I have relied on my local shop for all the regular care. As a hobbyist of many hats, my intention was always to take a more active role in the maintenance and repair of "The Baby". In light of Covid and time to finally detail my work shop, I have decided to join your forum with the hope of connecting with spirits of like mind to tackle the mechanical problems I never seemed to have the time to take on. First up is an ignition coil. Just before I was organizing storage for the car this fall, It started jumping into 'reduced performance' mode. A quick check with the mechanic found a faulty ignition coil. So late in the season, I elected to put her away and deal with it in spring. Central Canada winters are no place for a Jaguar XK8. Well now I am on my own to tackle the problem. The local shop is now closed and I did not take note of the faulty cylinder. Question..Is there a way to test for the faulty coil without a mechanics plug in scanner? I have rambled a bit but in reading the..how to be a good member.. sharing a bit more detail to start was recommended.
Old Apr 26, 2020 | 05:55 PM
Welcome to the forums James,
Any low cost generic scanner (or the Torque Pro App for Android) will enable you to read the Pxxxx (Powertrain) fault codes and determine which cylinder. A switch of this and another coil followed by a re-scan will determine if it is a faulty coil or some other cause of misfire. If the code moves with the coil, it's the coil at fault; if it stays with the same cylinder it's going to be harness etc.
Follow this link https://www.jaguarforums.com/forum/xk8-xkr-x100-17/ to the XK8/XKR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the Canada Region forum by following this link https://www.jaguarforums.com/forum/canada-73/ to find other members in your region.
Enjoy the forums.
Old Apr 26, 2020 | 06:08 PM
Boudxk8's Avatar
Hi Graham
Thanks for the quick and thorough reply. I will pick up the scanner and check out the suggested links. Be safe! JG
Old Apr 26, 2020 | 08:30 PM
Daf11e's Avatar
Welcome aboard James.
Old Apr 26, 2020 | 09:46 PM
Welcome to the Forums.
Old Apr 27, 2020 | 08:03 AM
Welcome to Jaguar Forums James,
Old Apr 27, 2020 | 08:08 AM
Old Apr 27, 2020 | 09:27 AM
Hello, James,
So many of us have time to do so many things we never had time to do before, Lots of this sort of things is getting done now, I'm thinking.
Old Apr 27, 2020 | 05:19 PM
o1xjr's Avatar
Welcome to the forums.
Old Apr 27, 2020 | 06:01 PM
Boudxk8's Avatar
Hi There
Thanks for the greeting.Im getting my feet wet checking things out. I have already learned a bunch!
Old Apr 27, 2020 | 06:02 PM
Boudxk8's Avatar
Hi Clarke
Old Apr 27, 2020 | 06:05 PM
Boudxk8's Avatar
This is so true! thanks for the welcome. I hope I can contribute as I begin to take on the maintenance for myself.
Old Apr 27, 2020 | 06:08 PM
Boudxk8's Avatar
Hey Steve
Thanks for the greeting. We have the identical XK8..Saphire Blue with ivory interior. Ive been cruising in this gem for 15 years!
Old Apr 27, 2020 | 06:09 PM
Boudxk8's Avatar
Hey Norri
Thanks for the greeting! I will be fleshing out my profile over the next few days. Very happy to be here.
Tom Baker
Oct 15, 2017 02:42 AM
patryk
Sep 18, 2016 03:06 AM
Jag-Type81
Apr 29, 2014 06:33 PM
ian_jaguar
Apr 18, 2012 06:23 PM
