New member needs help w/fuel fill problem
Old Sep 21, 2008 | 08:33 PM
queenmb's Avatar
Default RE: New member needs help w/fuel fill problem
[sm=welcomesign.gif]to the forum. I cant help with your issue, but hopefully one of our experts will be by soon with some advice. Good luck.
Old Sep 21, 2008 | 08:49 PM
Dennis's Avatar
ud
The obstruction you felt was probably the anti-siphon block..,,Other than that it maybe a vent issue..good luck and welcome.
Old Sep 21, 2008 | 09:46 PM
stkxjrtech's Avatar
does it flow slow or does the gas nozzle kick off like its full? Might also be a problem with the stations nozzle.
Old Sep 22, 2008 | 04:51 AM
twojags's Avatar
Hello and welcome to the forums.
Old Sep 22, 2008 | 08:38 AM
Stevegrmi's Avatar
Hello and welcome (I'm originally from Trenton, NJ) . . can't help with your fueling problem though . .
Old Sep 22, 2008 | 09:37 AM
Cadillac's Avatar
Welcome to the forums
Old Sep 28, 2008 | 11:06 PM
Brutal's Avatar
its not the stations pump, its either the cannister close valve under the car which is supposed to be open when not energised so as you fill the pressure goes out the charcoal cannisters and allows the gas to go in the tank, you can disc the pipe temporarily to check if this stops the problem(will set a ck engine light though for evap leak, just go to auto parts store and have them clear it) if this is not it its the evap loss cap on top of the fuel tank and the tank has to be removed to change this
Old Mar 18, 2009 | 01:25 AM
H20boy's Avatar
welcome new guy!
tberg
Sep 7, 2015 07:32 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
arnoldmilk
Sep 3, 2015 07:42 PM
KarimPA
Sep 3, 2015 07:32 PM
laserguy
Sep 3, 2015 02:02 PM
