Newbie with 2004 XJ
Old Jun 14, 2015 | 03:47 PM
paulfarah's Avatar
Post Newbie with 2004 XJ
Hello everyone - I own a 2004 XJ that has an electrical problem with multiple systems, as follows:
- Air conditioning turns on, but its blower won't run
- Air suspension pump does not run - it was leaky, but would always run
- Radio unit does not come on at all
- Driver side seat adjustment does not work
I have checked all the fuses inside the engine compartment, cabin and the trunk that had anything to do with the failed components and found them to be good.
History: The last problem that I had with the car was that it wouldn't shift out of Park - while pressing on the brakes - so I followed instructions I found on the web to remove the center console and the shifter to get to the gear lockout tab, which I removed, so I could then shift it out of parking.
Once I put everything back together and got the car to shift, I noticed that the air suspension was not pumping back up and then discovered that the air conditioning blower, radio and driver seat adjustments were not working either.
Other Clues: Prior to that I had a problem with not being able to open the trunk when the battery had died, during which I tried to power the instruments by connecting the charger to the engine compartment fuse box - which didn't help and caused the horn to go on. I eventually had to take the back seat off to access the trunk through the speaker holes and pull the cable that opens the trunk.
So I don't know if the electrical problems started after I dealt with the battery issue or the transmission lockout issue. I should note that I also had an existing front air suspension leak on the front passenger side and a noisy air suspension pump as well - both of which I have fiddled with a bit.
Potential Culprits: I am wondering if I may have accidentally disconnected a connector that would cause all of these systems to not work or if I may have blown a relay when I was dealing with the battery issue.
Any advice as to what connectors, relays or other areas I should look into would be much appreciated - as the problem is affecting multiple systems, most of which are motor driven, with the exception of the radio.
Many thanks for your time and help!
Paul
Old Jun 14, 2015 | 04:53 PM
Using JF "How To"
Old Jun 14, 2015 | 05:49 PM
Welcome to Jaguar Forums Paul,
Post up all the details in the tech section XJ XJ6 / XJ8 / XJR ( X350 & X358 ) - Jaguar Forums - Jaguar Enthusiasts Forum for all the help you need, don't forget the regional area also USA Western - AK CA NV OR UT HI WA ID - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jun 14, 2015 | 07:22 PM
<p>welcome to the forum - enjoy!!!</p>
Old Jun 14, 2015 | 09:41 PM
That's quite a list, Paul, I hope someone in the proper section can help you.
Old Jun 15, 2015 | 12:46 AM
Welcome to the forum Paul,
I've copied your post to X350 tech forum for advice from members with the same model. Here's the direct link to it :
https://www.jaguarforums.com/forum/x...roblem-144605/
Enjoy the forums.
Old Jun 15, 2015 | 05:26 AM
o1xjr's Avatar
trickeyM
Feb 29, 2020 07:00 PM
Msteiner
May 16, 2016 12:19 AM
Clare Jennings
Oct 4, 2015 05:43 PM
MrWhite
Oct 1, 2015 01:43 AM
millertic
Sep 30, 2015 08:11 PM
