Radio won't work fuse is fine. Help!?!
Old Oct 27, 2012 | 05:30 PM
Voss91si's Avatar
Default Radio won't work fuse is fine. Help!?!
Drove under tree branch doing under 5 mph and antenna hit branch. Then antenna went down. Lost power to radio. Checked all fuses and none are blown. Up for suggestions on what to check now. Help!?!
Old Oct 27, 2012 | 05:33 PM
Welcome to the forum Voss91si,
I think I can safely assume you have a Jaguar but a hint on model and year will go a long way to help us give you some advice...........................
Old Oct 27, 2012 | 10:46 PM
Old Oct 28, 2012 | 10:20 AM
Voss91si's Avatar
Sorry all. The car is a 2000 Jaguar XJ8 Vanden Plas
Old Oct 28, 2012 | 10:58 AM
Hi Voss91si,
That's a strange combination of events as they are separately fused. The radio/cassette fuse is No 9 in the rear compartment LH heelboard fusebox whereas the aerial is fuse No 9 in the Luggage Compartment fusebox.
There's a secondary fuse for the audio system at fuse No 3 in the Luggage Compartment fusebox so you should also check that one.
If that doesn't locate the issue, follow this link Follow this link XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 section for help, advice and information.
You can also visit the US Southwest Region section by following this link Southwest US - AZ TX NM OK - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in your region.
Is the tree OK?
Old Oct 28, 2012 | 07:56 PM
Hey & welcome aboard, good to have you here with us here at JF
Helpful_information
Please take the time to check out the regional section for your area?
See you in the forums
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
laserguy
Sep 3, 2015 02:02 PM
XFR_Gold
Sep 2, 2015 12:24 PM
