Xenon headlight problem Jaguar XE
Old Jan 21, 2021 | 12:51 PM
kev240's Avatar
Default Xenon headlight problem Jaguar XE
Hi, I am new to this forum, hello everyone. My problem is an intermittent fault on the drivers side full beam headlight, sometimes it works sometime not. My Jag model is the 2017 XE R SPORT. After trawling through lots of web pages I am even more confused. I know the headlights are xenon but do they have two bulbs or one and is it possible to change them yourself. I have also heard someone mention a shutter which operates high and low beam using only one bulb. Ive looked inside the headlight through the round hole but cant really work much out at all. Any advice would be greatly appreciated.
Old Jan 21, 2021 | 01:11 PM
Welcome to the forums Kev,
After looking at the Owner's Handbook and the Parts Catalogue, I can understand your confusion! The suggestion is that Halogen headlamps are serviceable but Xenon are not. Members with the same model will know more.
Follow this link https://www.jaguarforums.com/forum/xe-x760-85/ to the X760 forum for help, advice and information. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Old Jan 21, 2021 | 01:22 PM
welcome to the forum - enjoy!!!!
Old Jan 21, 2021 | 02:34 PM
Daf11e's Avatar
Welcome aboard Kev.
Old Jan 21, 2021 | 02:40 PM
kev240's Avatar
Thanks Graham
Old Jan 22, 2021 | 12:11 AM
Welcome to the Forums.
Old Jan 22, 2021 | 02:25 AM
Originally Posted by kev240
..... an intermittent fault on the drivers side full beam headlight.....
From the Workshop Manual:
All exterior lighting circuits are protected by Field Effect Transistors (FETs), located in the BCM/GWM assembly, which can detect overloads and short circuits.
The FETs respond to heat generated by increased current flow caused by a short circuit. On a normal circuit this would cause the fuse to blow. The FETs respond to the heat increase and disconnect the supply to the affected circuit. When the fault is rectified or the FET has cooled, the FET will reset and operate the circuit normally. If the fault persists the FET will cycle, disconnecting and reconnecting the power supply. The BCM/GWM assembly stores fault codes which can be retrieved using a Jaguar approved diagnostic system. The fault code will identify that there is a fault on a particular output which assist in fault detection.
This most likely explains the intermittent fault. Unfortunately troubleshooting will require Jaguar SDD (Symptom Driven Diagnostics) to see if there are relevant DTC's (fault codes).
Old Jan 22, 2021 | 06:50 AM
Welcome to Jaguar Forums Kev,
Old Jan 22, 2021 | 08:36 AM
Hello, Kev,
Old Jan 22, 2021 | 02:15 PM
o1xjr's Avatar
Welcome to the forums.
Old Jan 23, 2021 | 05:31 AM
kev240's Avatar
Thanks Graham, will be returning to Williams Jaguar as still under warranty.
Old Jan 23, 2021 | 06:49 AM
Fortunate as this could be an expensive repair. Let us know how you get on.
RBaczek
Oct 19, 2020 10:41 AM
XJsc-guy
Jun 14, 2017 08:31 AM
Eurobahn Jaguar
VENDOR Threads
Jan 18, 2016 03:57 PM
