Non-Jaguar Vehicles This area is designated for discussion about non-Jaguar Vehicles.
1967 Ford F100 XJR conversion
Old Oct 15, 2022 | 02:43 PM
david f100's Avatar
XJR Fuel pump fitted in to the F100
Old Oct 15, 2022 | 07:59 PM
89 Jacobra's Avatar
Active Streak: 30 Days
Well done looks like it will work just fine. That's thinking using the fuel pump assembly from the donor. that way everything matches and works as it was designed.
Jack
Old Oct 20, 2022 | 01:50 PM
wfooshee's Avatar
Just ran across this thread, and all I have to say is... WOW!!!
That's some good work, great fabrication!
Old Nov 9, 2022 | 01:43 AM
david f100's Avatar
New intake pipe
Old Nov 9, 2022 | 08:55 PM
89 Jacobra's Avatar
Nice having all the extra room, and hood clearance. Makes it easy to deal with things. Looks almost like it was meant to be in there.
JTS
Old Jan 31, 2023 | 01:44 AM
david f100's Avatar
a little Engine detailing ….
Old Jan 31, 2023 | 12:26 PM
89 Jacobra's Avatar
I think the Ford Blue is a little bit of a stretch. LOL! At least take a file, or some sand paper, and do the raised letters to expose the words, and the shiny aluminum. Hey just my thoughts.
Jack
Old Jan 31, 2023 | 12:56 PM
  #28
david f100's Avatar
Jack
Well, Ford did own Jag when this engine was manufactured , here’s the label on the XJR dash !
Old Jan 31, 2023 | 07:06 PM
89 Jacobra's Avatar
Good Point. Ford Blue it is.
Old Apr 19, 2023 | 08:50 PM
  #30
Addicted2boost's Avatar
Makin any progress with this?
Old Apr 20, 2023 | 01:16 AM
  #31
david f100's Avatar
Yes! Been doing lots of little jobs that needed doing but didn’t seem worthy of a post !
Lots of minor body work repairs
Rebuilt the A-post areas and fitted new floor pans,
Waiting for an overdue shipment from the US that has the bed repair panels and a new tunnel cover
Old Apr 20, 2023 | 07:45 AM
  #32
david f100's Avatar
fender repairs ….
Old Apr 20, 2023 | 08:13 AM
  #33
david f100's Avatar
Floor pans ….
Old Apr 20, 2023 | 06:07 PM
  #34
89 Jacobra's Avatar
Yeah those are very common rust areas on the old Ford Trucks. As old as it is, it's not as bad as a lot I've seen. In Illinois just south of Chicago they use a ton of salt in the winters and I've literally seen the doors with hinges break off/ rust off, and the whole frickin door fall off onto the ground. So it's good there was enough left to repair. LOL! Keep up the good work it just sucks that it's so time consuming.
Jack
Old Apr 21, 2023 | 05:27 AM
  #35
Scottsgreenjag's Avatar
From: Somewhere south of Grand Rapids, Michigan, USA
Default F100
Looked up your thread for the F100, you're doing an amazing job on the conversion.
Scott
Old May 23, 2025 | 01:38 AM
  #36
david f100's Avatar
Not posted for a while…. Been busy !
Old May 23, 2025 | 05:21 AM
  #37
Nice! How much weight do you have to put in the bed to keep those tires on the road. I’d bet it’s pretty easy to smoke them… Have you put it on a dyno to see what it puts out at the wheel?
Old May 23, 2025 | 09:55 PM
  #38
89 Jacobra's Avatar
Hey David. Damn Nice Truck! Wow, sure came out great. Hope it drives as good as it looks. Give us some details as it wasn't nearly this nice last we saw it. LOL! Lots of bllod sweat and tears, I'm sure.
Jack
Old May 24, 2025 | 01:14 PM
  #39
david f100's Avatar
Hi Scott, it’s not been on the dyno, I’m running the OE ECU, so no need for any remapping
but I have tubular headers, no CATs, and a big bore intake, so I guess it’s going to be a bit more than then stock 375 bhp, certainly feels it !
Old May 24, 2025 | 01:26 PM
  #40
david f100's Avatar
Hi Jack, yes lots of hours gone into it recently !
Ive had a few issues with Wheel speed sensors (as expected!)
But managed to locate the original OE diagnostic kit which helped to identify the issues
Still trying to stop the ABS and Traction control from engaging the ABS Pump, which is just an annoyance as the ABS module is now mounted in the cab!
Other than that, it’s running really good, sounds great, turns heads
Did a 400 mile round trip to the coast last weekend
