Other Jaguar Models / Concepts / Replicas Do you have a Jaguar model not listed above? This is the place to talk about it!
Engine / Transmission compatability
Old Mar 14, 2014 | 05:53 PM
Bad Cattitude's Avatar
Default Engine / Transmission compatability
I saw an SS100 replica for sale locally that had a GM (Chevy small block) drive train including an automatic transmission. From the look of the pan, it's a TH350. I seem to remember Jaguar using GM auto boxes for a while. What I am wondering is what Jaguar engine I could bolt up to the GM trans to make the car a bit more authentic?
Old Mar 15, 2014 | 02:44 AM
mlp442009's Avatar
go look at some of the latest threads on the xjs section seems a couple of the guys there may have all the answers
Old Mar 25, 2014 | 09:42 AM
Jagfixer's Avatar
You can use a 3.4L, 3.8L MK 1 and 2, 4.2 XJ6 1,2,3. The TH350 can be mounted to a Jag engine with interchange plate. The TH400 was used on V-12s. The original SS was a six cylinder like a MKV as it was not overhead cammed, but will need plate for tranny install. If you use the MK and XJ6 engines will be Hemi and dual cammed. Might check length of SBC to see if you have room for Jag 6. Or go modern with the X-Type V-6 and tranny. Also check height for hood/bonnet clearance.
RoyLittle0
May 25, 2023 02:38 AM
Bcrary3
Sep 12, 2021 05:41 AM
XJsc-guy
Sep 25, 2015 11:09 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
