jag S type R code P1254???
Old Nov 30, 2010 | 09:35 AM
JagV8's Avatar
It's a very high precision part. Similar price on various modern cars (Lexus etc). Lucky to find one so cheap....
Old Nov 30, 2010 | 10:56 AM
Pushing_Tin's Avatar
So I called about one of the used ones for sale and was told that the used part came out of a wrecked car that "only" had 70k miles on it. That doesn't inspire a lot of confidence in the used one as my car has less than that and it failed.
Old Nov 30, 2010 | 11:14 AM
Jon89's Avatar
I might consider a remanufactured throttle body for our S-Type, but I would never just go with a used one. These components are far too sensitive and prone to limp home mode failures if even the slightest amount of moisture gets into them....
Old Nov 30, 2010 | 12:45 PM
True, the car runs fine though. Not sure whether to replace it or just let it go for now and see what happens.
Old Dec 2, 2010 | 02:52 PM
Okay for anybody interested I found this auction and think it's the way to go. You send in your old throttle body, they rebuild and test and send it back. It has a lifetime warranty too. It was "only" $290.
http://cgi.ebay.com/ebaymotors/97-98...Q5fAccessories
Old Dec 3, 2010 | 09:57 AM
jag79's Avatar
Excellent find!! But I don't see in their description they rebuild s type supercharge models only 00'-05' s types?
Old Dec 3, 2010 | 10:15 AM
Originally Posted by jag79
Excellent find!! But I don't see in there description they rebuild s type supercharge models only 00'-05' s types?
I called them and asked. They were very friendly and helpful. I'll probably do this next week so I'll post up and let you know how it goes. I like the fact that you get yours back so there won't be any compatibility issues.
Old Dec 3, 2010 | 10:42 AM
  #28
jag79's Avatar
Sweet......and the best part it has a Lifetime Warranty! Will you be removing the Throttle Body unit yourself (DIY)? Look forward in hearing your Updates on how it goes.
Cheers.
Old Dec 3, 2010 | 12:37 PM
Cheers.
No, I'm taking the car to my mechanic and he's going to do it and send it off. While it's there he's going to change the valve cover gaskets, SC and serpentine belts. By the time he's done with all of that the TB should be back and ready to go!
Old Dec 20, 2010 | 07:36 PM
  #30
Got the TB back from UPS today. It only took about a week for the whole process, shipping both ways and the rebuild itself. It will be reinstalled the middle of the week.
Old Sep 25, 2011 | 06:15 PM
  #31
maggypaul's Avatar
Default 2003 S-Type-R
Hey , This must be a common problem for a great deal of these models. I have the same car with the same problem. Engine code p1254. The following is what happens to me : If the car is turned off before the motor is fully hot the next time the car is started it will be in the limp mode. To correct this problem the car has to run long enough to get fully hot and then restarted. The same thing happens if the key is turned to the access position, without starting the car. Is this the same problem ???
Old Sep 26, 2011 | 01:12 AM
  #32
JagV8's Avatar
Search shows that it's not common. My 2004 STR does not do what you just described. It sounds like yours has a fault. Check the codes PDF to see the known causes.
Old Sep 26, 2011 | 01:33 AM
  #33
gelomeloman's Avatar
Smile Nice
hi, guys, i bought a elm327 in this website ECUTOOL , it just cost me 13.44usd, it is very cheap and works perfactly.
Okay so I bought one on e-bay and got it hooked up today. The car had been sitting for about 5 days due to icy weather. Today when I started it I got the check engine light. So I hooked er up and got p1254 again, even though it had been cleared last week when it was getting a tune up. The software that came with the elm is pretty crappy and it's only a "demo" version so it won't tell me what the codes mean without paying to upgrade. What's the best way to fix this error once and for all?
Old Sep 26, 2011 | 01:55 AM
  #34
JagV8's Avatar
That's a good price. Remember it's ESSENTIAL to look up any P1 codes in the correct jag codes PDF - and wise to look up ALL codes in there (for the specific causes listed, at least).
(P1 codes are specific to make & model & model year)
Old Jan 14, 2014 | 12:19 AM
  #35
JagTalk's Avatar
I have the same problem P1254...
CEL is on, but rarely goes into limp mode.
Did the above fix it? Anyone know if the car will pass PA inspection with a CEL light?
stanjag
Dec 29, 2024 08:26 PM
philwarner
Dec 6, 2021 07:13 AM
Isoruku
Jun 19, 2020 12:54 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
NinoGrimace
Aug 26, 2015 05:15 AM
