Parking Brake Fault
Old Jun 27, 2011 | 11:00 PM
ajmainevents's Avatar
Default Parking Brake Fault
OK, So I have had my experiences with my jag but this is completely frustrating! As of recently every time I start my car it gives me a "Parking Break Fault" and a Yellow light. Well maybe not every time but at least 8/10. I need to restart a few times and it finally shuts off. But when its on the Parking Break is completely locked and i cant go anywhere!!! This is the newest issue. I love the car but its like a fickle girlfriend. I cant seem to ever make it happy!
Does anybody have advice or fixes? Let me know
Old Jun 28, 2011 | 03:03 AM
joycesjag's Avatar
Read this: https://www.jaguarforums.com/forum/s...e-stuck-32699/
Old Jun 28, 2011 | 05:50 AM
maxthrottle's Avatar
I feel your pain!
I have the same trouble with the 03 STR. The PB was making a louder noise for a few weeks before it quit all together, luckily the brake was in the OFF condition but followed by Park Brake Fault, yellow light ABS and BEEPING. A hard reset cured the beeping somehow, but the lights persist.
I noticed that the power would dip below 11 volts when starting so I thought a new battery would do it and bought a Evermax $95 unit at Walmart. (I know...Walmart) It was close and the battery fit perfectly, even has the offgassing port. Well it did not fix the problem.
I ordered a new PB Motor assembly from the local Jag dealer and I will pick it up today, I have my mechanic installing it at his shop tomorrow. I'm not comfortable dropping the rear differnential to replace this puppy. I hope that this fixes the problem and I dont need a module. (The module was replaced by recall in 2005)
With any luck you may just need a new battery
Old Jun 28, 2011 | 06:29 AM
joycesjag's Avatar
max I believe that AJ has the base model S Type therefore no seperate PB Motor as on the STRs. But if he does have an STR good advise.
Old Jun 28, 2011 | 01:04 PM
JagV8's Avatar
Er... what?
The 1999-2002 S-Type has no EPB (or motor) but all the 2003+ cars do. Don't they?
Old Jun 28, 2011 | 06:58 PM
joycesjag's Avatar
Isn't max reffering of the seperate motor on the rear wheel for the emergency braking on an STR?
Old Jun 28, 2011 | 08:11 PM
I know that the STR has two brake calipers on the rear wheels. The larger brake is the standard hydraulic brake and the smaller is the cable/electic motor actuated brake. I believe the S has one brake caliper that is both hydraulic and electric/cable applied.
Old Jun 29, 2011 | 03:04 AM
JagV8's Avatar
There isn't a separate motor like that. There's the EPB motor (as with other 2003+ cars) and that has bowden cables to the extra caliper on each side.
Old Jul 3, 2011 | 05:04 PM
JJ's Jags's Avatar
replacing the parking brake motor on 03 or newer S-Types is pretty common, I just did at 5-years and 60,000 miles on my 05-S-Type V8 Sport. Thank goodness for CPO! Dealer replaced it free along with the the motors on the fancy headlights
Old Jul 11, 2011 | 07:33 PM
Well guys I still have the problem. And its drivin me effing nutz!!! Tonight my wife and I were stuck in a parking lot for 20 minutes while I tried to rectify the problem. I have found that if I apply the foot brake as I start the car sometimes it helps. Maybe this is a fluid issue? Maybe due to the hot weather? I dont know but I cant afford a new EPB motor. Hopefully someone can help. Also I tried to recalibrate the EPB by the method recommended. No luck with that either. It doesnt work at all! Need some help here!
Old Jul 12, 2011 | 06:35 AM
What year kind of S do you drive AJ?
I am way to familiar with the STR Electric Parking Brake Motor and Phd12volt even more so.
From what I have discovered on the STR, the weaklink with the EPB motor is the integral gearbox that pulls on the cable. If the motor is still alive, you could remove it and clean out the road cinders and relubricate the fibre gears. You may be able to repair it yourself for the cost of dirty hands busted knuckles and a fingerfull of grease. The STR Parking brake motor is difficult to get to, tucked up under the differential, not sure about the S...maybe it would be easier.
In the meantime just push down on the PB paddle before you remove the key and the Parking brake should stay OFF.
Good Luck
Bob
Old Jul 12, 2011 | 10:15 AM
Leedsman's Avatar
When I'm parked in my driveway, which is level, I always disable the parkbrake by holding down the little chrome lever and removing the key; thus relying on the autobox park.
Leedsman.
Old Jul 12, 2011 | 10:23 AM
Mikey's Avatar
It's not likely to get better on it's own. Start by removing the rear wheels and examining the cable end and lever mechanism on the calipers. Have a helper set and release the EPB while you watch for cable binding or sticking.
I lubricate mine twice a year, so far so good.
Old Jul 12, 2011 | 06:20 PM
2005 S Type 3.0, 75000 miles
Old Aug 3, 2011 | 11:31 AM
Originally Posted by jagv8
Er... what?
Yes the 2005 does have a motor. And I have had it replaced and I am still getting the same issue.
Any help would be greatly appreciated!
Old Aug 3, 2011 | 11:36 AM
phd12volt's Avatar
when they changed the EPB motor, did they check the cables??
Old Aug 3, 2011 | 11:41 AM
xjrguy's Avatar
Check your other thread......... I have offered a couple of thoughts.
Cheers,
tomsjag
Jun 10, 2023 10:02 AM
neruda
Oct 18, 2015 01:19 PM
tonyforman
Sep 10, 2015 07:23 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
