Variable valve time solenoids
Old Jul 7, 2009 | 08:14 AM
JagV8's Avatar
I wonder if they swapped the wrong one on the first try? If there was a code (DTC), what was it? It might point to one or other bank - they're often described as "Left" or "Right" but of course you need to know which direction to be looking! Can also be numbered "1" and "2" and again you need to know which is which.
Obviously, you'd hope the garage would know what they were doing.....
Old Jul 8, 2009 | 12:08 PM
JagV8's Avatar
Many faults need to occur on two consecutive drive cycles (see the site stickies or google) or some similar time. Sorry not to be more specific!
Old Jul 12, 2009 | 04:48 PM
12RM's Avatar
This may be one of the known issues - I had this happen 2 or 3 time in 4 years of ownership.
Anyway the TSB is titled -
FALSE FLAGGING OF V6 CAMSHAFT TIMING DIAGNOSTIC TROUBLE CODES (1999 - 2001 cars)
Some of the text -
Summary
S303-09: This Technical Bulletin has been issued due to customer complaints of the Malfunction
Indicator Lamp (MIL) illuminating and Diagnostic Trouble Codes (DTCs) P1383 (valve cam timing
over retarded bank 1) or P1388 (valve cam timing over retarded bank 2) logging. (On occasions
both codes are shown)
After that it goes on to say that the dealer has to reprogramme the PCM (Power Control Module) using updated software.
I just reset using the battery disconnect method or a code reader once I obtained one.
You may have a real fault though.
Sprayall
May 30, 2021 08:13 AM
Kevin Burnaby
Jun 28, 2020 08:04 AM
Bowman
Sep 15, 2015 06:54 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
