05 str ac only on driver side heat on pass
Old May 2, 2013 | 03:54 PM
Worleybyrd's Avatar
Default 05 str ac only on driver side heat on pass
Ok I'm needing some help. I put the ac on today and I have ac on driver side but heat on pass. Side the dcc is set to 61* on both sides can anyone please give me some insit on this I did look at the dccv thread but really didn't help me with the problem I'm having thanks for any help
Old May 2, 2013 | 04:34 PM
tbird6's Avatar
Yes. Please do much reading and searching on DCCV and uneven heat and A/C.
Very common problem and lots of good info on this site.
Old May 2, 2013 | 04:55 PM
Worleybyrd's Avatar
I will reread it and maybe I just don't understand how this dccv works so if anyone thinks thats my problem please let me know like I said cold on one side hot on the other side so idk more reading for me tonight
Old May 3, 2013 | 07:15 AM
JagV8's Avatar
Start by expecting it is NOT working right then follow threads explaining how to test/fix.
Old May 3, 2013 | 09:59 AM
Michael Star's Avatar
Yup, DCCV is bad. Might as well replace the coolant reservoir if you haven't yet also.
Old May 3, 2013 | 11:36 AM
JOsworth's Avatar
Yup, do as Michael says... and soon before the failed DCCV takes out the Climate Control Module....
Again, you will understand that as soon as you do the heavy reading on this very common issue.
Old May 11, 2013 | 07:36 PM
TomSTR05's Avatar
I just fixed exactly the same problem on 05 STR,had hot air on drivers side and cold on passenger's, at first changed DCCV and the problem still remained.So after some readings on forum I took out RCCM,open it and found that 1 trace was burned so I went to electronic's repair shop and they fixed it. Cost? Just $15
Old May 12, 2013 | 05:32 AM
Sponge's Avatar
Another common problem is a broken wire in the loom leading to the DCCV, which is behind the front bumper. Follow the testing guide for the DCCV, if it shows valves are ok but control module is not switching, it may be the wire which is a cheep fix. That's what was found on mine a couple of months ago.
Good luck.
Old May 12, 2013 | 08:53 AM
JagV8's Avatar
$15 is a bargain!
Old May 13, 2013 | 03:11 PM
tbird6's Avatar
Hey! Good repair to that RCCM. That's the first picture I have seen of an actual repair on this module. Much more common to repair the CCM which comes with cars that don't have naviagation.
H20boy
Dec 24, 2024 03:23 PM
mbergen
Oct 23, 2019 10:26 PM
Dicque
Sep 19, 2015 12:53 PM
tberg
Sep 7, 2015 07:32 AM
Dallas XK8
Sep 3, 2015 12:17 PM
