05 str ac only on driver side heat on pass
Ok I'm needing some help. I put the ac on today and I have ac on driver side but heat on pass. Side the dcc is set to 61* on both sides can anyone please give me some insit on this I did look at the dccv thread but really didn't help me with the problem I'm having thanks for any help
I will reread it and maybe I just don't understand how this dccv works so if anyone thinks thats my problem please let me know like I said cold on one side hot on the other side so idk more reading for me tonight
Again, you will understand that as soon as you do the heavy reading on this very common issue.
I just fixed exactly the same problem on 05 STR,had hot air on drivers side and cold on passenger's, at first changed DCCV and the problem still remained.So after some readings on forum I took out RCCM,open it and found that 1 trace was burned so I went to electronic's repair shop and they fixed it. Cost? Just $15
Another common problem is a broken wire in the loom leading to the DCCV, which is behind the front bumper. Follow the testing guide for the DCCV, if it shows valves are ok but control module is not switching, it may be the wire which is a cheep fix. That's what was found on mine a couple of months ago.
Good luck.
Good luck.
Hey! Good repair to that RCCM. That's the first picture I have seen of an actual repair on this module. Much more common to repair the CCM which comes with cars that don't have naviagation.
Dicque
Sep 19, 2015 12:53 PM
