drivers side mirror replacement
Old Jan 2, 2011 | 04:24 PM
Don R's Avatar
Default drivers side mirror replacement
Happy New Year to all. Some SOB took a bat to my drivers side rear view mirror on my 03 S type and tried to knock it off by bashing it forward. Luckily it folded foward and everything stll works exept the glass is cracked and the liquid leaked out Is it possible to replace the glass only and how do you get the thing appart? Thanks, Don
Old Jan 2, 2011 | 04:51 PM
Riski's Avatar
check our vendors and ebay......prob be your cheapest bet....I doubt you will be able to just buy the glass
Old Jan 2, 2011 | 07:10 PM
joycesjag's Avatar
There is an ebay company that sells used mirror glass only. I needed one for my caddy, heated blinker dimmer etc... "bought it now" at $100.00 shipped. I will look for the company.
Removal don't quote me but I believe you use a flat screw driver and pry out the mirror glass, at least on the caddy, and glancing at ours it looks to be the same.
The ebayer I dealt with is flip-it-quick I just checked they have no Jaguar mirrors listed you may want to message them and see if they can locate one. Good luck.
Or I just did an ebay search, there are a few listed: http://shop.ebay.com/i.html?_nkw=Jag....c0.m270.l1313
Old Jan 2, 2011 | 08:06 PM
aholbro1's Avatar
Apply light pressure to the exterior mirror glass.
Detach the exterior mirror glass.
Apply light pressure to the inner edge of the exterior mirror glass.
Remove the exterior mirror glass.
Disconnect the electrical connectors.
To install, reverse the removal procedure.
I'll try to get the pictograms for you. Depends if you have the electrochromic and want to retain them. Think I saw a bunch of eBay for $56, mostly right side but left side can be found. However, if you want the electrochromic auto-dim, heated whatever.....$200+ and dealer is the only option I found.
Old Jan 2, 2011 | 08:12 PM
aholbro1's Avatar
here's the JTIS. It looks easier than it is....but it really does work this way...
File Type: pdf
Old Jan 3, 2011 | 02:03 AM
JagV8's Avatar
Available from ebay but not always exactly when you want it. Getting the glass back on I found so hard I had to remove the rear cover. Mine are electrochromic and powered and I didn't want to strip any of the plastic gears etc.
Old Jan 3, 2011 | 07:07 AM
joycesjag's Avatar
ahol (hee hee) nice attachment, thanks for posting.
Old Jan 3, 2011 | 07:11 AM
joycesjag's Avatar
jagv8, I found this one on ebay from a wrecker for $125.00, I know its the whole he'll get mirror assembly, but at that price I don't believe that much cheaper.
Old Jan 3, 2011 | 08:41 AM
Sponge's Avatar
Re the attached JTIS, it realy is that simple and easy. I've had mine out several times to tighten the frame screws. The first time you feel like your going to break the glass, just push at the window side and slide out at the outer edge.
Old Jan 3, 2011 | 09:39 AM
Don R's Avatar
Sorry, For some reason I can't view the JTIS in PDF? Don
Old Jan 3, 2011 | 09:41 AM
Don R's Avatar
How do you remove the rear carrier. I can't figure out how to get the outside unit apart. Thanks, Don
Old Jan 3, 2011 | 12:10 PM
JagV8's Avatar
Rick - that looks like a pre-2003 mirror (squarer shape).
Old Jan 3, 2011 | 12:50 PM
joycesjag's Avatar
Hmm sorry the OP said 03 and the ebay ad said 03. I am not familiar with the year styles. There are the newer style on ebay as well.
Old Jan 3, 2011 | 01:04 PM
JagV8's Avatar
ebay's a reasonable hunting ground either way
Old Jan 3, 2011 | 08:33 PM
aholbro1's Avatar
Don't know if it will be much help, but sometimes I feel more comfortable if I know what's on the back side of what I'm prying against. Here are pics of the one I changed out, (a 2003 electrochromic) and the box labels of the new piece.
Attached Thumbnails drivers side mirror replacement-img_20110103_202101.jpg   drivers side mirror replacement-img_20110103_202147.jpg   drivers side mirror replacement-img_20110103_202157.jpg   drivers side mirror replacement-img_20110103_202225.jpg
Old Jan 4, 2011 | 01:43 AM
JagV8's Avatar
Good pics. The last one shows the two short locating plastic bars at left and right sides. They clip over plastic parts on the rest of the door mirror body.
I'm told you can remove the rear covers (aka shells) using fingernails but I needed a knife edge to lever mine off.
Old Jan 7, 2011 | 03:32 PM
JagV8's Avatar
Aha! Jag have some help:
This http://topix.jaguar.jlrext.com/topix...document/61728
is actually a PDF (rename it)
More here: http://topix.jaguar.jlrext.com/topix...document/98417
also a PDF
Old Jan 15, 2011 | 04:44 PM
Don R's Avatar
It looks like you push out away from the car while pulling away from the mirror housing on the outer edge of the mirror. Is that right? how hard do you push and pull? What is snaping loose?
Old Jan 16, 2011 | 11:49 AM
androulakis's Avatar
Hey,
Don't know if you've seen this yet but figured it was worth posting:
Take care,
George
File Type: pdf
Old Jan 17, 2011 | 09:39 AM
Don R's Avatar
Geo. For some reason i can't open this to view it? Don
