Motorcraft Platinum FS22's
Old Aug 27, 2012 | 12:06 PM
Leonard_85's Avatar
Default Motorcraft Platinum FS22's
Hello all,
Spark Plugs,
Looking to locate the Motorcraft Platinum AWSF FS22 for S-Type 2000.
Does anyone have a specific part number useful to a UK search and supply. It appears "AWSF FS22" only draws attention to across the pond.
Thanks,
Old Aug 27, 2012 | 12:32 PM
abonano's Avatar
Leonard_85 - I believe NGK double platinum plugs are OEM standard for the 00 S Type...
Old Aug 27, 2012 | 02:02 PM
Leonard_85's Avatar
OK,
Well i've just removed all 6 motorcraft platinums from our car.
Looking at images of of the NGK double you mentioned the thread appears to continue along entire shank, the Motorcrafts are short threaded.
Old Aug 27, 2012 | 02:49 PM
abonano's Avatar
Here you go off of www.rockauto.com website:
NGK Part # 5598 {#PTR6D13} Laser Platinum
From 10.98; Auto (AJ V6); European Market Only
Old Aug 27, 2012 | 03:09 PM
Six Rotors's Avatar
You could try www.advanceautoparts.com for the info you need.The 2000 Lincoln LS with 3.0V6 came with AGSF 32FSMF6 as far as I can see,0.679in reach full thread.These are fine sinle platinum,good for 100k miles.
Is it possible the previous owner put the wrong plugs in?
Old Aug 28, 2012 | 05:39 AM
Leonard_85's Avatar
Those links are great thanks,
See image.
Thread is barely 0.4 inch - tapered neck must finish closure.
I wouldn't be surprised if previous owner purchased lawn-mower plugs. We could write a book about the fun we've had.
Is there a limit to length of thread before damage may occur?
Thanks,
Old Aug 28, 2012 | 07:16 AM
Six Rotors's Avatar
The important measurement is from thr seat to the tip of the electrode--you don't want the plug and piston to come in contact.And anti-seize lubricant on the threads really helps.
Old Aug 28, 2012 | 08:36 AM
abonano's Avatar
2 things....
One, that plug Leonard_85 looks like toast! I have used NGK double platinum plugs since I've owned my Jag and have been very satisfied. I pulled out the original plugs (4.0 V8) at 100K miles and they looked better than the plug in the pic.
Two, I have heard six rotors to not use anti seize lubricant on the plugs on these cars... I don't know how true that is but have used it on every other vehicle I've owned. Just my $0.02
Old Aug 28, 2012 | 10:06 AM
Mikey's Avatar
What brand and part number are specified by Jaguar?
Old Aug 28, 2012 | 10:19 AM
Six Rotors's Avatar
I just checked the JTIS and Jaguar specified AWSF22FS.They also specify the use of high temperature nickel anti seize lubricant for the threads.Funnily enough they do not specify anti seize lubricant for the 4.2V8 but they do for the 4.0V8!
Old Aug 28, 2012 | 10:34 AM
Jon89's Avatar
I had been under the impression that the factory-installed Motorcraft AGSF22FSM spark plugs in our 2005 S-Type 3.0 were iridium-tipped. I learned today that they are NOT iridium-tipped, they are platinum-tipped. While they are relatively good plugs that Jaguar schedules for replacement at 100,000 miles, nothing comes close to the longevity and trouble-free operation of iridium plugs. So when I decide to replace these factory plugs (our S-Type is approaching 72,000 miles now), I'm going with NGK iridium plugs. That should mean that I'll never have to mess with the spark plugs in this car again....
Old Aug 28, 2012 | 10:37 AM
abonano's Avatar
JTIS - 3.0 V6 - AWSF22FS - as six rotors pointed out.
JTIS - 4.0 V8 - Jaguar Part C2A 1535 (NGK - Double Platinum - PFR5G-13E)
Old Aug 28, 2012 | 02:25 PM
Leonard_85's Avatar
Correct, all six have been well and truly spit-roasted.
I cleaned-out the threads today on the cyclinder block - there are no more than 5 complete turns tapped which explains the shorter threads, obviously all thread is not utilised on NGK etc...
Does the AWSF-FS22 code refer simply to Motorcraft or not...?
Old Aug 28, 2012 | 02:57 PM
Mikey's Avatar
Yes, that's a Ford part number and it seems that that these plugs are now discontinued and superceded. I get all sorts of part numbers pop up as cross references. maybe ask at your local dealer what they use?
Old Aug 28, 2012 | 04:08 PM
Leonard_85's Avatar
Yes, the shorter thread tells me they're very specific to that very engine block.
Another mystery tour then, discontinued - something tells me you know your food spares and might just know the new part number or have a catalogue collecting dust somewhere?
Old Aug 28, 2012 | 04:10 PM
Leonard_85's Avatar
ford*** spares.
Old Aug 28, 2012 | 04:37 PM
Mikey's Avatar
ford*** spares.
I wondered about that. LOL
Alternative spark plugs for MTRCRFT AWSF22FS
Old Aug 28, 2012 | 04:46 PM
Gus's Avatar
Gus
I installed Bosch +2 in my 2000 S-Type 3.0 about 30,000 mi and they are still working just fine.
Old Aug 29, 2012 | 06:34 AM
Leonard_85's Avatar
Thanks Gus,
Jaguar specify NGK TR6AP-13E as replacement plug for AWSF-FS22's.
I have had the Ford people scratching their heads all morning.
Old Aug 29, 2012 | 07:30 AM
Gus's Avatar
Gus
That choice is yours but the car will not die with another type plug in it and I can verify that.
