Slightly Squeaky Steering Wheel
Old Nov 30, 2010 | 08:03 PM
clint25n's Avatar
Default Slightly Squeaky Steering Wheel
Does anyone notice on a 2003ish S-Type R that the steering wheel slightly squeaks when steering. You can usually only hear it when the radio is off. I will pay close attention next time and try to better describe the squeak. But thought I might not have to if it turns out to be a common problem. Maybe the assembly needs grease??
Old Nov 30, 2010 | 08:26 PM
ChrisSTR's Avatar
Common issue use the search feature. It can be easily solved in most cases by visiting your jaguar delear and picking up a bottle of a power steering lubricant they offer for this very issue.
I just started developing the same little annoying whine. It's barely perceptible.
Old Dec 1, 2010 | 11:29 AM
+1 on ChristSTR.....check out the power steering additive
Good luck
Old Dec 1, 2010 | 01:44 PM
red high heels's Avatar
Correct me if I'm wrong here but I think he is talking about a the actual steering mechanism and not the power steering pump whine. Is this correct? Anywho I have the same annoying sqeak like the bearing or bushing needs to be lubed.
Old Dec 1, 2010 | 02:29 PM
JagV8's Avatar
The bush can be a cause of a squeak but usually it is the pump. The additive is very cheap and generally works so is usually the first thing to try. There's a TSB about the bush, too, I think but basically you replace it if the problem turns out not to be the pump. I guess lubrication will work but you'll probably have to keep redoing it.
Old Dec 2, 2010 | 02:52 AM
clint25n's Avatar
Yes, I'd be surprised if it was the pump, but I'm no mechanic. I've heard noisy pumps before while steering. But this is more like a squeaky Windex cleaning noise coming from the steering wheel or column. Like leather on leather, or perhaps a rubber seal. Maybe I can post a video.
But it probably wouldn't hurt to try the additive.
Old Dec 2, 2010 | 03:06 AM
JagV8's Avatar
Well..... it's not the pump, it's a seal (or several) - as Search and the FAQs would tell you - but you just use the additive. It's cheap and easy. Otherwise it's the bush and you replace it but I bet it's a lot more work and may cost more too.
Old Dec 2, 2010 | 12:48 PM
Either way, the important thing is, once you have fixed the issue, return here and post what it was for future members
Old Dec 2, 2010 | 02:56 PM
zogg's Avatar
Talking I just fixed mine...easy fix
My 06 was having the exact same symptoms....can only hear it with radio off.
The Jaguar dealer sells a 50 ml bottle of "stuff" that is an additive for the power steering system. The local Jag dealer is 2 hours away, so he shipped it to me...cost $12 for the "stuff" and $8 shipping....got it the next day.
There is a long an elaborate procedure associated with the TSB for this issue....I did not do all of that.
I sucked out as much power steering fluid as I could with a turkey baster, re-filled it with Mobil Synthetic Multivehicle ATF (Dexron an required according to the owners manual). Drove it for two days, and re-did the same thing....two more times. This was an attempt to swap out as much old fluid as possible.
The last time I sucked out the fluid, I first added the Jaguar "stuff" and filled it up with the Mobil ATF....
Then I started the engine and let it idle for a few minutes. Then I turned the steering wheel lock-to-lock 4 times.
Drove the car about ten miles, and no more noise...that was about 4 weeks ago. I was especially concerned about the really cold weather setting in, but absolutely no issues so far.
So, pretty eash fix....give it a try for $12....the dealer wanted $300 to do the job?!?!?!?!?!?!?!
Old Dec 2, 2010 | 04:53 PM
tbird6's Avatar
The noise is not the pump. It's from a seal in the rack and it's transmitted up the steering column. I have attached the TSB with the correct part number for the additive. The Lincoln LS also suffers from this and Ford has a similar additive. I still wonder if they are the same magic juice??
Old Dec 2, 2010 | 06:34 PM
Mikey's Avatar
That is PRECISELY what the pump seal sounds like. Try the additive.
Old Dec 2, 2010 | 06:35 PM
clubairth1's Avatar
Community Influencer
It's a seal in the rack NOT a seal in the pump. The pump is not the problem but it does sound like it is.
Old Dec 2, 2010 | 06:45 PM
bcantr7's Avatar
the p/s additive will fix this problem 90% of the time
Old Dec 2, 2010 | 08:01 PM
FloridaJag's Avatar
I like the steering wheel squeak. It adds character to the car.
Old Dec 2, 2010 | 09:08 PM
clubairth1's Avatar
It does but I was just so happy to have a fix this simple and cheap!!
Old Dec 2, 2010 | 09:19 PM
Frank M's Avatar
Mine squeaks too occasionally. Its the clock spring for the air bag on mine. We are so used to it we don't hear it.
I added the fluid and it has been quiet for a year now..
It was not the clock spring and I was very leery on using "magic" additives.
I have egg on my face now!!
Old Dec 3, 2010 | 06:19 AM
Jon89's Avatar
I did the additive TSB myself in late March 2010. The steering wheel has been silent as a tomb ever since. As inexpensive as this D-I-Y step is, everyone with a squeaking steering mechanism should try this first....
Old Dec 3, 2010 | 06:58 AM
carelm's Avatar
In addition to the additive, I periodically spray lithium white grease (CRC I think) on the steering column u-joints. That seems to quiet any resisual noise. I also use this on the brake pedal mechanism, the door jambs and locks. The S-Type seems to have been assembled "dry" in that the various mechanisms don't have the lubrication other cars seem to have.
Mike
Old Dec 3, 2010 | 12:49 PM
clint25n's Avatar
Yes, exactly what my wife said. We had a Lincoln LS before and she said that made the same noise. Thanks. I'm gonna go buy that magic juice as soon as I can find it this weekend. Two problems down, unknown more to go. This forum is saving me millions.
Old Dec 3, 2010 | 03:33 PM
tbird6's Avatar
If you need the Lincoln LS part number for the magic juice it's in this TSB I have attached. The Jaguar version is in the first TSB I posted.
File Type: pdf
