Starting problem
Old Feb 25, 2012 | 11:26 AM
hersham boy's Avatar
Default Starting problem
I'll start at the start. the car is a s type 3.0 ltr manual. Ok its been parked up over the winter (inside) so when i went to the car the battery was flat. I removed the battery and recharged, getting distracted i then did not replace the battery for about 4 weeks. with a fully charged battery the key fob no longer arms/disarms the alarm/immob when i put the key in the ignition and turn it, the streeing lock does not disengage and the only light that comes on is the airbag light. I'm stummped. It was 100% fine when parked up. Help........
Old Feb 25, 2012 | 11:43 AM
JagV8's Avatar
Try to get more data about the electrics.
E.g. do any lights work? Do any work which impose a heavy load (headlights, fogs, ...)?
Measure voltage at the battery and as far from it as you can, both with the biggest load you can impose. Ideally at the starter motor.
(Because many batteries are effectively dead following what you posted.)
Next, how dry is/was the "inside"?
Old Feb 25, 2012 | 03:14 PM
I have replaced the battery with a new one. i have also replaced the battery in the alarm fob. The inside is dry (kept in a garage). The radio is asking for a code but the lights etc do no work at all. Only sign of life is the radio and the airbag light.
Old Feb 26, 2012 | 08:18 AM
JagV8's Avatar
I'd use a voltmeter and follow the various stuff shown in the appropriate guide from JTIS or here
Jaguar electrical reference
Try bypassing the radio code using FFWD (>>) & AMEM & PTY (together).
Bear in mind some things will work (at least partly) with hardly any volts but not others.
Old Feb 28, 2012 | 01:26 PM
Ok i have now got most of the electrics working. Still can not get ignition lights, I think this could be an immobilizer problem. The doors now lock and open, the alarm sets and turns off but the doors auto lock as soon as you open them with the fob. almost sorted so anyone else help with tips or idea's?
Old Feb 28, 2012 | 01:53 PM
Default Is it possible to bypass the immobilizer/alarm
Or remove altogether.. Having loads of electrical problems. sorted most (see other thread) but now i have the key fob working again when i unlock the door they auto relock stright away. Also i can't get any ignition lights on the dash and can not crank the car.
Old Feb 28, 2012 | 02:18 PM
JagV8's Avatar
If the alarm sets and unsets I don't believe it's immobiliser-related. It might be something like the gear shift interlock (which isn't really immobiliser) or the contacts related to ignition (also not immobiliser).
Old Feb 28, 2012 | 02:23 PM
JagV8's Avatar
No it's not. By law (EU & UK).
Which is why it's built into the PCM and parts are in other modules as well.
You don't appear to have an immo problem as I've answered in your other thread. BTW, you won't be loved by the mods if you create multiple threads.
Old Feb 29, 2012 | 12:37 PM
Finally sorted :-) still have the locking unlocking problem but its switched from keep locking to keep opening. But i have ignition and the car runs and drives.. will sort other niggles over the next couple of days. Thanks for your help..
Old Feb 29, 2012 | 12:52 PM
The miggles i have left to sort
Radio code (don't have AMEM button so cant try the ffw amem pty thingy
central locking.
no milage readout on dash.
new alloy last one kerbed big style.
MOT and Tax and i'll be back on the road
find and buy a cd changer for the boot.
Old Feb 29, 2012 | 01:10 PM
JagV8's Avatar
What got it started and running?
Any jag dealer can get you the code if you provide proper ID and proof of ownership - or email jag.
Old Feb 29, 2012 | 03:10 PM
One of the larger fuses. checked them all before by sight and all seemed fine. decided to do a continuity check on them all, 1 had a very fine hairline crack in it. replaced and away she went.
JarodL
Mar 7, 2024 01:39 AM
alpecsa
Sep 7, 2015 11:55 AM
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
laserguy
Sep 3, 2015 02:02 PM
