Stereo and Amp Question
Old Jan 17, 2015 | 02:50 PM
Cartierusm's Avatar
Default Stereo and Amp Question
Ok I'm a noob on the forum and I have searched, but still have a couple questions.
Just pickup a used 2001 Jaguar S Type with V8, Premium Sound and Nav.
I want to replace the stereo.
I've noted a wiring harness adapter is hard to find but a 86-04 Ford Harness should work.
Other than that it seems pretty easy as in this year the climate controls won't get messed up?
I guess my only question is, is the current premium stereo installed have built in amps or are they outboard?
Thanks.
Old Jan 18, 2015 | 10:00 AM
JagV8's Avatar
Never mind that till you've checked and probably changed the timing chain tensioners!
Old Jan 18, 2015 | 12:50 PM
Cartierusm's Avatar
@JagV8, is that something that goes bad quite often?
I'm not going to change the stereo unless I can find adapter cables as I would want to put the stock stereo back some day. I found two of the cables from a Ford kit, but not the others.
Old Jan 18, 2015 | 02:14 PM
JagV8's Avatar
The originals will fail and write off the engine. You're on borrowed time
Old Jan 18, 2015 | 06:53 PM
Cartierusm's Avatar
Ok thanks. I'll check them out.
Old Jan 19, 2015 | 02:53 AM
Cartierusm's Avatar
Ok found the electrical schematics and see that the head unit is separate on my premium system from the center fill amplifier and the sub-woofer amplifier.
So my two questions are:
1. where are these amps located?
2. Most after market head units only have 4 ouputs, such as front left, front right, rear right and rear left. So when I get my after market unit I figure it will have amplified power out for FR, FL, RR, RL and then pre-outs for the same. So I should wire the FR, FL, RR, RL to the powered outputs and then wire the center fill speakers with Pre-out for FR and FL, then wire the subwoofers to the pre-out for RR and RL?
Am I on track?
Old Jan 19, 2015 | 04:04 AM
Paul792's Avatar
This is from the Jaguar s type workshop manual page 116, under audio and communication system.
"The Premium Sound System components differ to
the base system as follows: ....
¥ Two active center fill speakers (with amplifier)
¥ Active sub-woofer enclosure mounted under
the rear parcel shelf ..."
The link to quote and manual in pdf is: http://www.jagrepair.com/images/Auto...G%20S_Type.pdf
I hope this helps.
Old Jan 20, 2015 | 12:02 AM
Cartierusm's Avatar
yes, thanks. that's the one I found.
Old Jan 20, 2015 | 01:11 AM
Cartierusm's Avatar
Ok So I'm trying to decipher the schematic and have a couple of questions.
1. Wires going directly to the speakers, how do i determine which is positive and which one is negative.
2. Some of the plugs are split up, so some wires on one plug go to some of the wires for the amp and another plug has the rest of the wires going to the amp. I take it that's normal? Cause when trying to determine what plugs refer to locations on the schematic sometimes there's more than one location it can refer to.
3. Technically there's 4 wires going to the amp, one braided line and then 3 others. How do i determine which goes where on the new stereo. I take it two wires are for the pre-amp signal and the other two are power?
4. Should I be concerned with making sure any wires get hooked up that affect condition of the car, such as a wire on the schematic labeled as 'Security System Radio Ground Sensing'.
5. There are extra wires on the car that don't show up in the schematic. So I assume I won't really need those anyway. As long as I hook up the wires I need for the new stereo?
Any help would be appreciated. Thanks.
Old Jan 20, 2015 | 03:40 AM
Cartierusm's Avatar
Ok that was a lot of questions. I think I have most of it figured out.
For the speaker polarity they all use variants of White and Slate. So am I correct in thinking White is positive and Slate is negative?
For the amp wires, braid, yellow, white and slate; white is positive, slate negative, braid ground to chassis of head unit and yellow being control wire for when the car power is on, what the head unit labels as "connect to terminal controlled by the ignition switch".
I think the only thing I'm confused about now is if there's wires that need to be hooked up to keep the cars integrity, such as:
what is the audio control protocal network, and security system radio ground sensing?
Old Jan 21, 2015 | 12:17 AM
Cartierusm's Avatar
Ok so I figured out more. So I was correct slate is negative and white is positive.
The only thing I'm confused about is the wiring for the amp. It has braid, white, slate and yellow. But I'm told the yellow is a control wire. So how does it have two channels going out and one RCA input from the stereo.
Old Jul 29, 2018 | 01:48 PM
mikchek's Avatar
did you ever figure it out Cartierusm?
Old Aug 7, 2018 | 10:42 AM
mikchek's Avatar
i was told by a shop that you don't have to worry about the timing chain tensions on a s type
Old Aug 7, 2018 | 12:46 PM
S-Type Owner's Avatar
Then I would find another more competent shop...
JR
Old Aug 7, 2018 | 04:57 PM
DigitalDisaster's Avatar
Absolutely false. A tensioner failed on my 2000 4.0 at 130K miles. I was lucky as no catastrophic damage was done, outside of that to my wallet.
Old Aug 8, 2018 | 07:34 AM
mikchek's Avatar
good to know
mbergen
Oct 23, 2019 10:26 PM
adam699
Sep 12, 2015 05:32 PM
tvholden
Sep 12, 2015 11:13 AM
AL NZ
Sep 4, 2015 08:39 PM
