"Creaking" noise coming from front end
Old Jan 13, 2009 | 05:24 PM
marktmv's Avatar
Default RE: "Creaking" noise coming from front end
Have you changed your swaybar bushings lately? I had an "old-door" type of creaking after installing new bushings. I had to take them off and apply some graphite lube to quiet them down.
Old Jan 13, 2009 | 06:58 PM
Real_Tech's Avatar
Noises are difficult to diagnose on the internet but common problems that cause creaking noises are dry tie rod end and ball joint sockets. The noise these make is most noticeable on undulating pavement and driveway entrances rather than hard bumps. If you have a needle oiler you can put some lube into the boots of the mentioned components one at a time untill you correct the problem and then you will know which one to replace. I would start with the outer tie rod ends as these are the most common.
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
jdzubas
Oct 4, 2015 09:14 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
CaneCounsel007
Sep 3, 2015 07:33 PM
