**official** intake elbow group buy thread
Old Mar 29, 2011 | 07:07 AM
  #161
The Chris X's Avatar
Finally uploaded some pics of my Mafioso install with the T-clamps.
The clamps are rotated in a manner that allows the hood to close and the plastic engine cover to be refitted. There is very minimal contact with the T-clamp and insulating hood liner - I noticed two little slits in the liner from the top of the clamps on the manifold side. To address this, I simply flattened the top of the T-clamps. They have sharp little protrustions on each side, a few quick taps with a mallet and they are flat and no longer poke the insulation.
I also added a hose clamp to provide additional security for the PCV hose barb connection on the valve cover.
So far very pleased with the intake! Looks good, sounds great.
Attached Thumbnails **official** intake elbow group buy thread-intake-6-.jpg   **official** intake elbow group buy thread-intake.jpg   **official** intake elbow group buy thread-intake-4-.jpg   **official** intake elbow group buy thread-intake-5-.jpg   **official** intake elbow group buy thread-intake-1-.jpg
Old Mar 29, 2011 | 09:38 AM
  #162
Enthusiast's Avatar
Beautiful. Hate the clamps though.....
Old Mar 29, 2011 | 11:23 AM
  #163
I'm on the fence about the clamps. Trimmed up would be better for sure.
The only one that I wouldn't put a worm drive clamp on is the top one on the manifold side - it mates the oval shaped manifold intake to the round Mafioso intake. It took a good bit of crankin' on that T clamp to make me satisfied it was a good sturdy connection.
I might paint the clamps black.
Old Mar 29, 2011 | 01:06 PM
  #164
StypeR's Avatar
Looking good, Chris X! Are we all sure there's no air leaks around the manifold intake due to the oval/round mating - especially at WO throttle? Mafioso? Also, which hose you talking about that you put extra clamps on? Can't wait for mine!
On the fence whether I like the plastic cover on or off...pffft.
Old Mar 29, 2011 | 02:58 PM
  #165
Thanks, but credit goes to Mafioso for the looks.
I am very confident there are no air leaks with these T-clamps. The clamping force is very good, the clamps are wide, and the rubber connectors are very snug on the intake and manifold sides even without the clamps. If there is any unmetered air sneaking in there, it ain't enough to do anything IMHO.
I put a worm drive hose clamp on the vac line from the valve cover to the intake. This is where some had reported the rubber fitting had split.
You can see the fitting in this pic on the right hand side. It has a zip tie on it in this pic, but I replaced it with a hose clamp later on.
Attached Thumbnails **official** intake elbow group buy thread-intake-2-.jpg
Old Mar 29, 2011 | 03:09 PM
  #166
vance580's Avatar
Here is a pic of it clamped. I did this after mine split and I got a new one and its been fine ever since.
Old Mar 29, 2011 | 04:01 PM
  #167
Mafioso's Avatar
I started to send the little hose clamp for the PCV fitting, and everyone will get the NORMA fitting once I locate them.
Old Mar 29, 2011 | 05:15 PM
  #168
StypeR's Avatar
Thanks Chris X and Vance! Will take pics of mine when done as well! USPS - hurry up already!
Old Mar 29, 2011 | 07:38 PM
  #169
Michael Star's Avatar
Ive been meaning to take a pic of mine but have been super busy. I had one of those since installed and I haven't had a single problem.
thanks for posting the pic!!
Old Mar 30, 2011 | 02:23 PM
  #170
Dimension247's Avatar
Mafioso do you still have any left over BEST elbows with T-clamps? I'm interested in one. If there are none left do you plan to do another run anytime soon?
Did anyone order and install the Riski Red.
Old Mar 30, 2011 | 05:54 PM
  #171
Mafioso's Avatar
Im trying to get another thread started with the requests, so I can keep track properly.
Old Apr 1, 2011 | 12:58 AM
  #172
STRaightJAGgin's Avatar
Mafioso, im also interested in a "best" intake.. i noticed a member received a very bright red one... are custom colors xtra?? if so, how much? id like mine in Dodger Blue please .. please keep me posted. thanks.
Old Apr 1, 2011 | 11:12 PM
  #173
StypeR's Avatar
Got mine this afternoon! Thanks, Mafioso! I want to do this myself but anybody know how to remove that black plastic engine cover? I searched on here and couldn't find anything. I'm thinking it's pretty simple, right? Thanks in advance!
Old Apr 1, 2011 | 11:14 PM
  #174
vance580's Avatar
Should just lift up. Its not bolted or anything just slips in some tabs. Gentle pull got mine off. Its hanging in the garage now like the looks without it.
Old Apr 1, 2011 | 11:33 PM
  #175
StypeR's Avatar
Thanks Vance! That''s what I thought but needed some input! I can't wait for tomorrow...doing it right now! haha..
Old Apr 1, 2011 | 11:43 PM
  #176
vance580's Avatar
Yea I've heard a few people that its a little tight cause the little rubber piece that it slips into will swell a little making you think its bolted or something so just pull it a little harder and it will eventually come off.
Old Apr 2, 2011 | 12:07 AM
  #177
StypeR's Avatar
Got the cover off..decided to clean the engine first. how do you remove the OEM PCV hose on the valve cover?
Old Apr 2, 2011 | 12:53 PM
  #178
vance580's Avatar
[quote=StypeR]Hey Vance,
In case anyone else is having trouble with remove this hose here are some pics that hopefully will help people. There is a ring at the bottom part of it. You have to squeeze each side of it to get the other two sides to clear the lip on the valve cover its the same on the intake side. If you look at these pics there is a ribbed portion that if you push those it will let the tabs clear the lip.
Here you can see the 2 tabs that lock it in place.
Here is the indents that you need to push.
This is how you would squeeze and it will make that ring oval letting the tabs clear then you should be able to pull up.
Old Apr 7, 2011 | 04:32 PM
  #179
StypeR's Avatar
Here's mine installed. Waiting on the rest of the T-clamps (thanks Mafioso!). Butt dyno feels a better throttle response and faster revs. Will try to get a video soon.
All in all, workmanship is excellent on the product - if there is one thing to nitpick on is that maybe the weld on the tube could be on the underside? But like I said, that's just nitpicking and looks great as it it. I cannot believe how "complicated" that OEM intake is.
I'm open to suggestions whether to paint it or leave it as it is. And still back and forth as to whether to put the plastic valve cover back.
Attached Thumbnails **official** intake elbow group buy thread-str-intake-01-sm.jpg   **official** intake elbow group buy thread-str-intake-07.jpg   **official** intake elbow group buy thread-str-intake-10.jpg   **official** intake elbow group buy thread-str-intake-08.jpg
Old Apr 7, 2011 | 05:54 PM
  #180
Mafioso's Avatar
Leave it polished and take a alum. polishing wheel and a drill to the intercoolers
