00 jaguar s type tail light problems. Help?
Old Aug 21, 2010 | 10:02 PM
Mafioso's Avatar
First thing to check is the brake switch found on the brake pedal. Disconnect it remove it and check for continuity in pressed on position with a DMM no continuity in either position replace continiuity both ways replace
Old Aug 22, 2010 | 08:47 AM
JagV8's Avatar
See forum FAQ / stickies for free download of handbooks
Old Aug 22, 2010 | 09:36 AM
Gus's Avatar
Gus
Look at your light switch first and see if the light control switch is not pointed to the far right pointing to oval light with a squiggly line. That is your rear fog lights. Rotate the control switch to the left to the upright position (arrow up “O”) that is lights off, then get a copy of the owner’s manual/handbook. I hope this helps!
Old May 13, 2024 | 06:18 PM
Jaguar king's Avatar
Default Break light staying on or not coming on at all
Originally Posted by renojag
I just bought a 2000 Jaguar S-type 3.0 V6. As soon as i connect the battery the rear tail lights come on as if someone was pressing the brake pedal. Have no clue what this could be, please help??? Would check the fuses but don't have the owners manuel. Any help would be appreciated. thank you
Check under th break pedal it's a button under there look all the way up there you'll see it it's a rubber button it's its gone replace it it will fix your problem if now it's a fuse in the trunk or electrical problems
Old May 14, 2024 | 08:38 AM
S-Type Owner's Avatar
Jaguar king, welcome to the forums. It does not look like "renojag" has been back since his August 2010 post...
When you find a moment, please post the expected "introduction" in the New Members forum; it can be found here:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
MJ'S Jag
Nov 10, 2022 08:14 AM
swarm27
Aug 29, 2015 07:37 AM
NorJag
E type ( XK-E )
Aug 28, 2015 07:31 AM
gene1
Aug 27, 2015 08:56 PM
Terrance Williams
Aug 26, 2015 11:50 AM
