00 S Type Front Outer Bar Link Replacement
Old Aug 8, 2012 | 08:17 PM
abonano's Avatar
Default 00 S Type Front Outer Bar Link Replacement
Hi, so I had the inner tie rods and tie rod ends installed on my 00 S Type with new boots (both sides for safe measure) - I wound up going under the car to check the work performed (good habit I say) and I found the sway bar link (driver's side) - rubber boots cracked and broken - the sway bar link is intact - I'm going to replace both sway bar links but the question I pose is as follows:
Should I get the allignment done before I get the replacement sway bar links installed or should I wait?
Would installing those sway bar links throw off the allignment?
Any advice would be appreciated. Thanks
Old Aug 9, 2012 | 07:44 AM
abonano's Avatar
I guess after 19 views I received my answer - wait....
Old Aug 9, 2012 | 12:19 PM
Six Rotors's Avatar
Actually it does not matter.The end links on the stabiliser bar do not affect alignment.(Check front alignment procedure)
Old Aug 9, 2012 | 03:36 PM
abonano's Avatar
Thanks Six Rotors
stanjag
Dec 29, 2024 08:26 PM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
Paradigm
Jun 15, 2019 05:59 AM
aquifer
Aug 29, 2015 04:54 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
