01 S type draining battery
Old Feb 24, 2015 | 04:19 PM
cruisesinc's Avatar
Default 01 S type draining battery
I have an 2001 S type that is draining the battery when sits for more than a day.
If I pull fuse # 20 in the passenger compartment fuse box the draw drops enough that the battery will stay up. Manual says it controls GEM module instrument and A/C. I needing to know if there is anything common that shorts on these. Or Does anybody have a wiring diagram of this circuit,
Old Feb 24, 2015 | 05:58 PM
JagV8's Avatar
It's part of the free download JTIS
Old Feb 24, 2015 | 06:13 PM
NBCat's Avatar
Originally Posted by cruisesinc
I have an 2001 S type that is draining the battery when sits for more than a day...
+1 on download of JTIS.
The next thing to consider is the age and condition of the battery. Unless a voltmeter tells you otherwise concerning a draw with the ignition switch in the off position, a more likely cause is a failing or weak battery that does not hold a deep charge.
The charging system may also need to be checked to ensure the alternator is functioning correctly and that all connections are clean and tight.
Old Mar 3, 2015 | 09:00 AM
cruisesinc's Avatar
Battery New Alternator is charging OK
Old Mar 3, 2015 | 02:47 PM
NBCat's Avatar
Are you still experiencing the same condition when the vehicle is not driven for a few days?
stanjag
Dec 29, 2024 08:26 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
TXJagR
Mar 12, 2016 11:12 AM
dcvickers
Sep 2, 2015 06:14 PM
Thia
Sep 1, 2015 10:36 AM
