02 S-type won't start
Old Aug 2, 2009 | 04:10 PM
katproffitt's Avatar
Default 02 S-type won't start
Help! Car won't start - battery works (ie seat moves up, lights come on and everything), but engine doesn't even try starting.
Any ideas on the possible causes? My gas gauge said I had about 23 miles left to go before empty. If it runs out of gas, does the engine not even try to start? I also just had my transmission rebuilt last month, so could this problem be related to that?
Old Aug 2, 2009 | 04:14 PM
JagV8's Avatar
Why not add more fuel and try then?
Old Aug 5, 2009 | 03:31 PM
southernjaggirl's Avatar
Hi Katprofitt -
Any luck with your jag?
Old Apr 15, 2021 | 09:53 AM
Backhertz's Avatar
Default Need to check fuel pressure.
The good thing if it’s the fuel pump, there’s no need to drop the tank or cut anything. Just remove the ~8” cover over the fuel under the rear seat on the passenger side.
Before doing all that , check the usual suspects & see if the pump is getting power. These pumps are notorious for failing.
Good luck.
Andis28
Apr 15, 2021 03:51 PM
OldMike
26
Nov 5, 2013 05:46 PM
jvickers
Apr 11, 2013 11:45 AM
David Type S 01
Jul 1, 2010 11:42 AM
Mar 1, 2007 11:09 PM
