04 STR with Magnaflow exhaust system
Old Apr 23, 2011 | 11:49 AM
ttwotees's Avatar
Default 04 STR with Magnaflow exhaust system
Hey guys; Just thought I'd let you know my new exhaust system is working fine, not too loud and feels (seat of the pants) like substantially more power. Here is what I installed:
Exhaust tip (2)-Magnaflow part # 35190$73.23 x 2=$146.46
Resonator (2)-Magnaflow part # 11226$63.05 x2=$126.10
Muffler (1)-Magnaflow part # 11386 $80.29= $80.29
"X" pipe1Magnaflow part # 10791$67.86 =$67.86
Cat Conv (2)-Magnaflow part # 54976$65.83 x2=$131.66
All parts ordered from www.performancepeddler.com
I now have sound clips, but they are in .avi format which is not one of
the attachments allowed, so if you want to hear 'em, send me your e-mail address to ttwotees@att.net.
The muffler is a 2 in and 2 out like the original. First sound clip is outside
the car and second one is inside with windows rolled up but not in gear.
Old Apr 23, 2011 | 09:48 PM
bfsgross's Avatar
Thanks ttwotees. I may switch some exhaust parts to match yours once I hear your sound clip. When ya gunna dyno?
Old Apr 25, 2011 | 06:44 AM
achysklic's Avatar
Hi all the parts you listed are 2.5 the stock exhaust is 2.25 did you change the orginal pipe to 2.5 or do I need to order the 2.5 parts to fit one my 2.25 pipe.
Sorry for all the questions on exhaust stuff, just realy want to get it right.
Also I noticed you got 1 muffler and 2 res. Is this normal or did you mean to say you got 2 mufflers and 1 res.?
Old Apr 25, 2011 | 09:57 AM
bfsgross's Avatar
Achysklic, ttwotees maintained the stock 2 1/4" pipe, having the new pieces (2 1/2" inlet and outlets) fitted to connect to the stock pipe.
Old Apr 25, 2011 | 10:16 AM
achysklic's Avatar
So I should also get the 2.5 parts to fit to my 2.25 pipe?
Old Apr 26, 2011 | 03:48 AM
bfsgross's Avatar
yes
Old Apr 26, 2011 | 03:54 AM
bfsgross's Avatar
achysklic, ttwotees mentions one muffler and two resonators in a fashion that the (one) dual inlet/outlet muffler replaces the mid section stock resonator and the two resonators are mufflers...just a way some see it.
Old Apr 26, 2011 | 06:04 AM
ttwotees's Avatar
I used the 2.5" pieces, but that was an accident. I thought the original was 2.5" until we started welding. I'd use the 2.25" if I had to do it again and 2.25" is available. I don't think there's anything to be gained by going larger except if you think it's cool looking. I don't think so and it complicates the job for no gain.
Old Apr 26, 2011 | 07:10 AM
achysklic's Avatar
Thanks for the replies I was just wondering if I got the 2.25 parts would they fit over the factory 2.25 for welding? I fiqured you went with the 2.5 so it would slip over the 2.25 and weld easy.
Old Apr 26, 2011 | 08:20 AM
bfsgross's Avatar
You have a n/a 4.2, so definitely go with ttwotees; staying with 2 1/4" components and pipe. The exhaust installer will expand the ends of the 2 1/4" inlet/outlets (of the new muffler components) to slip over the 2 1/4" exisiting pipe. If your placing hi-flow cats, x-pipe, and dual inlet/outlet muffler; you'll find the only stock pipe remaining is a small section after the muffler and the pipe that goes over the rear axle assembly to the rear boxes (mufflers).
Old Apr 26, 2011 | 09:43 AM
ChrisSTR's Avatar
Seth,
If I understand your setup your x-pipe is in the same place your resonater used to be onto glasspacks on into your mufflers. Right?
Old Apr 26, 2011 | 11:43 AM
vance580's Avatar
If I'm picturing it correctly his exhaust will look similiar to this. He will have the high flow cats going into an x-pipe with after the x-pipe looking similiar to the pic. What he listed as resonators are mufflers if you look up the part#. The center muffler is the part# 11386 and the left and right ones are what is listed as the resonators. Is this correct ttwotees.
Old Apr 26, 2011 | 08:51 PM
bfsgross's Avatar
Yes, the x-pipe is just after the transmission output shaft. The 12" Walker glass-packed tube mufflers (resonators) are placed just before the rear axle. This setup is similar to many factory setups.
Old Apr 27, 2011 | 05:56 AM
ttwotees's Avatar
Yes that is correct. When I was much younger, the central device was called a muffler and the devices placed at the end of the exhaust pipes were called resonators. Magnaflow calls all of them mufflers because you can use them anywhere
in the exhaust system. I don't believe they list anything called resonators, but then
it's all semantics anyway. (grin)
Old May 2, 2011 | 07:12 PM
GPstr's Avatar
Thanks for the clips ttwotees, the car sounds great!
clubairth1
30
Sep 3, 2025 04:38 PM
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
Daim
Nov 28, 2016 09:28 AM
XJ8JR
Sep 11, 2015 12:31 AM
rachelstr
Sep 3, 2015 12:59 PM
