05 STR leaking transmission line
Old Mar 19, 2011 | 09:01 PM
hotstr's Avatar
Default 05 STR leaking transmission line
Was doing a oil change today when I took off the bottom cover I seen oil on it looks like the transmission line is leaking. Is this a dealer part. I can't find it online
Old Mar 20, 2011 | 08:01 AM
Is this the line to the cooler?
Is it leaking where the rubber section joins the steel part ?
If so a search should provide a lot of info.
Old Mar 20, 2011 | 09:57 PM
hotstr's Avatar
yea thats where it looks like its leaking thanks. I will look there.
Old Nov 18, 2013 | 03:25 PM
WhiteKitty's Avatar
Default Leaking transmission line
I think I have the same problem, but not sure, so I took a few pics and hope to get some info on the piece that simply looks like a bracket to hold the two lines???
Is this just a bracket for the two "one-piece" lines, or does it join four lines?
There is fresh fluid at the bottom of the black plastic bracket piece...
See attached pictures and thank you in advance for your knowledge!!
Attached Thumbnails 05 STR leaking transmission line-imag0004.jpg   05 STR leaking transmission line-imag0005.jpg   05 STR leaking transmission line-imag0006.jpg
Old Nov 19, 2013 | 11:11 PM
WhiteKitty's Avatar
I did some more searches around the forums and found out that our lines going to the trans cooler are one piece.
So this black plastic piece is just a bracket.
Usually the lines leak at the rubber to metal crimp?
I checked those areas and the lines look bone dry...hmmm
I will look some more in the next couple days to see if I can find any pinholes or areas where the leak could be coming from.
I wonder if some sort of epoxy could be applied to the outside of the line with a crack/pinhole in it instead of replacing/cutting out?
clubairth1
30
Sep 3, 2025 04:38 PM
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
rachelstr
Sep 3, 2015 12:59 PM
