06 S Type 3.0 blew out spark plug
Old Mar 10, 2018 | 08:46 PM
55chevy's Avatar
Default 06 S Type 3.0 blew out spark plug
Sonded like a knock while driving, stopped at a mechanic and he felt a coil on plug, making the most noise, front passenger cylinder, No 4? After I removed the coil I found it damaged, the plug was loose,when I went to loosen the plug it was loose, and it was missing the electrode completely. I had a Ford 5.4 Triton engine that blew out plugs 3 times, it's such a common problem you can buy a repair kit that taps a new sleeve and plug in the cylinder, I wonder if one of them would work on the Jag? Or what is the best way to fix it?
Old Mar 11, 2018 | 04:07 AM
Bugga,
We use Helicoils if you can at teh hole, and a 3ltr would be testy at best.
A "nut sert" is another option.
That Ford fix sounds OK also.
Most spark plugs are the same thread, 14mm from memory.
For the electrode to be mashed, it must have hit the piston, so maybe the wrong plug from the go get.
Old Mar 11, 2018 | 12:48 PM
JagV8's Avatar
A new problem for an S-Type I think. Been here 7 (*) years and still something unexpected pops up.
Not an OE plug I'd say!
edit: (*) I meant nearly 9
Old Mar 12, 2018 | 08:29 AM
55chevy's Avatar
When my Ford spit out a plug it took the coil on plug with it, the Jag didn't so it wasn't as noticeable, I haven't figured out why the electrode was missing though.
Old Mar 12, 2018 | 09:09 AM
JagV8's Avatar
Someone put in the wrong kind?
Old Mar 12, 2018 | 09:55 AM
Mikey's Avatar
Are the threads in the head stripped?
Old Mar 15, 2018 | 07:07 AM
Warspite's Avatar
Typical of like generation Ford engines, since there are only 2-3 threads to hold that plug in. Usually the root cause is use of "hotter" plugs, which expand the threads in the head, eventually leading to a spark plug projectile.
On the Ford F-150 forum, the recommended fix is the "sert" job per Grant's post, and OEM plug only (aftermarket, platinum ones are usually the culprit).
Lagonia
Feb 12, 2022 11:18 PM
rjcl004
Dec 28, 2013 09:38 AM
GvilleVDP
Jun 6, 2013 08:20 AM
SteveJacks
Dec 7, 2011 06:50 AM
benebob
Sep 15, 2010 09:12 AM
