07 3.0 lower intake part number
Old Oct 17, 2017 | 03:04 PM
Paulie710's Avatar
Default 07 3.0 lower intake part number
Hi,
I have an 07 Stype 3.0 does anyone have a Ford part # that crosses for the lower intake manifold??
Old Oct 17, 2017 | 03:18 PM
The manifold or the gaskets?
Old Oct 17, 2017 | 03:25 PM
NBCat's Avatar
Originally Posted by Paulie710
Hi,
The lower inlet manifold and associated gaskets are VIN-specific. You will need to supply the last six digits of the VIN to determine the correct part numbers.
Old Oct 17, 2017 | 05:27 PM
Paulie710's Avatar
Default Vin # N73561
The last 6 of my vin are N73561 and I am looking for ford cross #s for the lower intake as well as upper and lower gaskets.thanks
Old Oct 17, 2017 | 06:27 PM
joycesjag's Avatar
Hmm I just did a quick ebay search, looks like the Ford Five Hundred lower intake manifold is a match. I do not have 100% proof though.
FelPro makes tried and true aftermarket gaskets (seals) for the 3.0 liters. If you haven't noted already, be sure to have valve cover and bosses gaskets on hand, they are known to leak into the spark plug wells. Very simple to replace when you have the motor torn down to the lower intake.
Old Oct 18, 2017 | 04:13 AM
Paulie710's Avatar
Default I just looked at the Ford 500 intake does it look the same
I just looked at the Ford 500 intake it does not look the same
Old Oct 18, 2017 | 05:53 AM
So you do want the manifold?
Old Oct 18, 2017 | 08:59 AM
NBCat's Avatar
Based on your VIN, the lower manifold part number is C2C32349, which has been superseded to C2C41691.
The upper gaskets part number is XR843536 of which, six are required.
The lower gaskets part number is XR843533, which also require six.
You may be able to have a Ford agency provide the FoMoCo part numbers if you give them the engine number.
Old Oct 18, 2017 | 11:56 AM
joycesjag's Avatar
I wasn't sure as mentioned. Its been along time since I was under the plenum.
GL with pursuit.
