2000 jaguar s-type 4.0 cranks but won't start
Old Dec 15, 2014 | 08:42 AM
camw510's Avatar
Default 2000 jaguar s-type 4.0 cranks but won't start
The car was driving fine but had been sitting for a while a few times the past months, I had just drove the car 40+ miles parked it for 5 minutes and drove it again no more than 4 miles when car lost power after a U turn
I have not check much since this did just happen last night...tank is 1/2 - 3/4 full, pressure at fuel valve (spray)not sure of psi , tried starting in park and neutral did not fire up much only a little sputtered and had car tow home. Any suggestions on fixing would be greatly appreciated.
Old Dec 15, 2014 | 01:40 PM
tbird6's Avatar
Try some starting fluid and let us know what it does.
Sounds like you lost something major electrical?
Do you have lights? Anything electrical acting odd?
Old Dec 15, 2014 | 05:02 PM
abonano's Avatar
Possible fuel pump failure. (electrical or fuel pressure)
Check: inertia switch
Fuel pump fuse and relay.
Fuel pressure at rail before start up - should be at least 40 psi.
Hope this helps.
Old Dec 18, 2014 | 08:58 PM
motorcarman's Avatar
Is the PATS light on the top of the dash at the windscreen 'flashing' with the KEY ON, ENGINE OFF?????? or does it illuminate steady for 3 seconds (prove-out)??
bob gauff
Old Dec 19, 2014 | 02:44 AM
camw510's Avatar
inertia switch not tripped, electrical not acting up no sensor lights on, need to get pressure gauge to check psi at valve and fuses...thanks for the tips will check back in with findings...
Old Dec 19, 2014 | 04:03 AM
JagV8's Avatar
See Bob's post re PATS.
MJ'S Jag
Nov 10, 2022 08:14 AM
nelsonht
Aug 30, 2015 06:01 AM
Drew2006
Aug 28, 2015 04:22 PM
peterg19
Aug 28, 2015 08:42 AM
NinoGrimace
Aug 26, 2015 05:15 AM
